r32 drivers side guard, in perfect codition, in primer, ready for paint $80 (THE ONE IN PRIMER, BAD PIC SORRY)
ORIGIN rear bar, same colour as side skirts, in good condition, has a chunk cracked off, easily repaired going for cheap $120ono bump now $70 dollarsssssssssssssssssssssssssssss ono
heres some pics and what they look like on a 180
have a pair of nexen 3000 radials for sale 235/45/17, local only, very good tread, bit of camber wear, only driven for 3000km still very new, have a geezer at the pics
price is $200 for the pair now $150
4door r32 spoiler type a very rare, COMES WITH brake light $120 or make me an offer, comes with the two rubber seals in perfect condition, spoiler is in immaculate condition now $50
r32 rear bar does not come with reverse lights as on has broken only rhs reverse light is available
$70 or nearest offer YES IT IS A TYPE M REAR BAR
r32 boot TYPE M in navy blue, comes with lock and is in perfect conidiotn has type m rear spoiler in blue as well
r32 drivers side guard in primer ready for paint, perfect condition has all the mounting points
$ 90 or nearest offer
r32 rear reo in perfect condition with working number plate lights, comes with the loom as ewll
r32 front strut brace, in good condition, used only once on a car for like 200 km if that then the car was stripped
$120 ono
r32 cluster surround, manual type m in good condition all mounting points are there
not sure what they re worth but i know they re always cracking $120 ono
r32 cluster surround, auto type m in good condition all mountin points are there and not broken
$80 ono
Vertex bar, in immaculate condition, has been professionally painted in gloss black (NOT CANNED), has one small crack but nothing major, has metal mounting bits (come for free) has been heatgunned professionally to fit flush with stock 180sx guards.
$250 OR NEAREST OFFER, might be expensive so offer me a price, also it does not have any cracks underneath, so structurally is perfect, has scrapage from driveways but no cracks!
imperfections are shown as follows
Greddy turbo timer, never used, came with the car as a spare cos the owner upgraded before he even put this one on, perfect turbo timer has other functions too
has loom as well so goes straight in
$120 ono POSTED
Earls, transmission cooler/oil cooler, in very good condition a bit battered but holds oil and is in perfect running orrder comes with anodised fittings and braided lines
$350 or nearest offer (not sure what its worth)
r32 drivers side indicator, clear and maber, has crack 30 posted
ca seats for silvia/180sx, in very good condition, drivers side has a bit of wear due to going in and out of the car, normal wear, $70 for the pair, in grey colour, very nice factory colour
ca18det stock wheels, in perfect condition, 3 tyres are 80% other tyre is pretty bald, good for roadworthy $150 for the set now $120 ono
180sx rear reo bar, in perfect condition $70
pm if interested guys cheers
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
