Hey All
for some reason my battery is over volting causing battery acid to leak in the boot
i dont know what could be causing this or what the solution is , ive removed the battery and cleaned out the boot with baking soda to rid the acid
but this is the 3rd battery its done this to :P
does anyone have any idea what could be causing this?
i dont wanna go buy a new battery to have it explode a day later ....
cheers heaps !
https://www.sau.com.au/forums/topic/325410-battery-over-volting/
Regulator in the alternator is stuffed. If you don't get it fixed / replaced, you will continue to kill batteries.
so is it a matter of replacing the whole alternator
or is it just a part of the alternator that needs replacing?
There are some spare parts regulators available. What is the part number of your alternator. I'll see what I have got.
http://www4.wave.co.nz/~lakewood/Skyline/Alt.htm
Nigel
if you don't fix it then you can end up damaging more than just batteries. the alternator in my grandparents car stuffed, was putting out 18 volts and blew the wiper motor (which wasn't on at the time but it just started to go full speed and wouldn't stop), blew the headlight bulbs, dash light bulbs and tail lights.
My alternator is doing the same thing. The turbotimer is telling me it's making 15 volts and the battery light is on. When it drops to below 14.5v the batt light turns off. Checked it with multimeter also. The workshop I took it to said it was overcharging but should be fine :D I really hate that battery light. Will get that regulator fixed one day when the hole in my wallet recovers.
Like was said, its your regulator.
Had this problem in the 32 GTR about 6mths ago.
Luckily noticed it early, and had no battery explosions.
Best to go get it fixed asap, cause as mentioned, it can affect more then just the battery.
The GTR didnt like 18v. It messed with the speakers, ABS, etc.... Thankfully no permanent damaged occurred.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
