  • 1 month later...
  • Replies 50
Posted Images
  • 9 months later...
Been a while,
clutch fixed, replaced a piston and head gasket, custom surge and breather tanks, 3x bosch fuel pumps ready for E85.
scored some series 2 taillights as well
Edited by RED513
  • 4 weeks later...
  • 3 weeks later...
pics? :rolleyes: Your 32 is really coming along nicely. Congrats on a really keen car mate
No pics as its messy atm
Trying to track it for some sprints but motor keeps smoken.
Bought a spare head last weekend, In getting full reco with mild port job,
Just undicided on bottom end??? 25, 26 or 30??? Do have spare 25 block which has been tapped/drilled/cleaned, ready for bore/forgies.
All comes down to money!
Edited by RED513
go the 30 :ph34r: , pics of your car all messy , i wanna see what you did with the 2d skirts
RB25 still has 160psi across all six, valve stem seals ??? (no smoke when boosted below 4k rpm)
Spare head being built, mild port job, full reco, gtr cams, solids and valves, no vtc. Will restrict oil supply, drill block and head oil returns whilst off, external return kit.
Just keeps going! lol
  • 1 month later...
  • 3 weeks later...
This is one tough 32 four door man. Love the GTR bonnet n grill combo on foru doors.
The '25 with the 3037S is tits! Nice man, love what your've done.
Keep up the good work!!!! :)
Thanks mate, step 1 RB30DET nearly ready just needs assembling
So far:
Rb25 head. light port, drillled, full reco, std cams, no vtc
RB30 Block, std bore, restricted, drilled and debured.
Crank collar, grub screw, linish and balance.
std pistons and rods, new rings,
new acl race main and rod bearings.
new N1 oil pump and waterpump.
genuine gasket set and cometic headgasket.
  • 3 weeks later...
RB30DET running :nyaanyaa:
Rb25 head. modified, drillled, full reco, no vtc, 20 inlet cam, 25 exhaust cam, dayco 94407 timing belt,
RB30 Block, std bore, restricted, 1xhigh/1x low tensioner, drilled and debured, genuine gasket set, 1.2mm cometic headgasket
RB30 Crank, collar, grub screw, linish, std pistons and rods, new acl race rings, main and rod bearings.
New N1 oil pump and waterpump, Greddy oil cooler and relocator, Greddy style manifold, 850cc, 2x 044 pumps, 1x 040 intank pump.
Still running GT3076 .63 with 38mm tial gate under manifold & same tune from rb25.
Going to move gate and plumback with new stainless dump then tune on E85.
Gold Coast 4 door <3 :D
We have 3x skyline 4 doors:
Mine, R34 4door and another R32 4 door, all highly modified
Pop in anytime:
FFF MOTORSPORTS
5/14 bailey crescent
Southport, 4215
Matt 0414 233 005
Edited by RED513
Pop in anytime:
FFF MOTORSPORTS
Southport, 4215
Matt 0414 233 005
Yeah nice!
Sounds good. should be on the road within the month ;)
i got a build thread in the build section.
have a good one.
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
