Hey guys, i have an r34 GTT, and about an hour ago, i was braking, and the car really felt like it was shaking. i took my hands off the wheel doing about 60 and tried again, and the wheel was shaking like crazy. When i rolling about 20, slow down then jump on the pedal, the sound it makes is like my front bumper is scraping the ground, which i know for a fact is not.
i have checked the front and back pads, both fine, checked brake fluid, fine. checked my abs fuses, both fine.
Anyone able to help me here as why its doing this, cheers guys.
https://www.sau.com.au/forums/topic/325422-car-shakes-when-i-brake/
my brother in laws 32 did that it was something with the front suspension get it checked at pedders its like 29 bucks to check.. if it feels like the whole car is shaking then i think thats the prob.. hope this helps
took the wheel off, rotors look fine as a mate said aswell. He took it for a spin and obviously it didnt happen.
He said the fluid may have got so hot and boiled. Has this ever happened to anybody????
is it auto??
Our car used to do it,mainly when going down big hills, where brakes are working hard.
happens alot with autos,Falcodores owners are constantly changing discs but the Rotors arent actually warped, but residue from pads gets baked on to the rotors..You know when u sit at the lights with brakes on, pads are really hot..Apparently some good metallic pads and hard braking can clean it off, but i havent tried it...
Either way get them machined..
no need to take discs off, you can get them machined on car..Any brake place even kmart tyre an auto can do it ,about 110$
Edited by Arthur T3
brake and shake baby - had to be said
hahaha nice.
It has stopped the shaking now, well, the day after anyways, so now i dont know about the rotors anymore??
Its back to normal and i havnt changed anything.
is it auto??
Nah mate its a manual.
hahaha nice.
My money would still be on rotors. Could have been glazed, but I would still say they are warped...
But also check your tyre pressures. Happened to me on the weekend, felt like something was very very wrong, like the wheels were about to fall off, steering wheel shaking violently, car wasn't handling properly... Checked the tyre pressures the next day, and they had dropped quite low. Pumped em up to 38psi and that fixed all the problems. I doubt you are experiencing the same thing because my problems weren't while I was braking, more while I was cornering. But worth a go anyway.
Edited by Hanaldo
That's actually the cause of 99.9% of shudder. It's called DTV (disc thickness variation) and is caused by cheap pads, and/or excessive float in wheel bearings... which leads to the pad material being laid down unevenly.
It's VERY VERY rare that rotors actually warp. It simply doesn't happen, even on race cars. Even rally car that get them glowing hot then go through water spashes don't 'warp' rotors. It doesn't happen. It will be DTV. Machining them will fix the problem, but it often doesn't curing the underlying problem.
Commodores are really bad for shudder, and it's always excessive float in the bearings, which starts the problem, then the pad material being laid down unevenly on the rotor because it's not rotating square finishes it....
Some light reading by car engineer legend Carrol Smith:
http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
    • Dragging some reo behind a ute or trailer will smooth out a dirt road, I've used reo a few times to do unsealed road maintenance when we didn't have any plant available  It's best done when the dirt is wet though, and then you just let it dry out for a day to harden up For wetting the dirt I've used some 44 gal drums in a ute or trailer, and a water pump connected to a hose with a old sprinkler tied to the reo to wet the material down whilst spreading Basically just drive slowly up and down the road a few times dragging a few sheets of reo wired together with the sprinkler wetting it all down as you go
    • I did a motokhana years ago with ??Sydney Sporting Car Club???, it was on a grassy paddock and was heaps of fun, I think it was north west Sydney IIRC The old R33 boat was covered in grass and dirt, but nothing that a good wash and detail didn't fix And thinking back, when SAU did the airstrip run in Goulburn years ago, where the old 33 won highest RWD MPH, the quickest RWD ET on the airstrip, and best paint IIRC (before the runs down the airstrip) the damage to the rear quarters from stones flicking up required them the get a respray  I would definitely do a grass motokhana again in the MX5 Who knows someone that owns a farm with a big empty paddock  Liability these days is a big issue though
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
