R34.5 Front End Conversion
snozzle
 Share
That car has been around for quite some time, all I can help you with is it was done in Japan....
  • 2 months later...
  • 3 months later...
The rear quarter panels look like they were just stuck on as an afterthought. "Oh shit, the front is a lot wider than we expected. Quick, lets put some panels on the rear to make it match". Fail.
IMO the front of the R35 it too rounded for an R34 rear. I'd like to see this conversion on an R33 - they lend themselves better to rounded bodywork and wide body kits.
  • 3 weeks later...
Looks ok, but will cop alot of abuse from haters. :P
I think the R34 converted in the photo is a GT-T, not a GTR right?
Judging by the spoiler you would think so, but look closely, it has the gtr rear bar.
Huhh...ok. I thought all fenders were pumped and modified.
In that case of converting a R34 GTR to this, I think it's a waste. :(
yet it has no mfd on the dash... and the confuzzlement continues.
in regards to the OP, no... just no
  • 5 weeks later...
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
