Hi guys,
I recently brought a r33 gtr and it has got the common coil pack problems as it miss badly and sometimes when cold it even stalls. My question is I used to own a r33 gtst s2 and I have a set of splitfires and harness from that, can I wire them into the gtr so I can use those splitfires and also it gets rid of the ignitor box thing?
Cheers,
Trav
https://www.sau.com.au/forums/topic/325477-puttin-s2-coil-packs-in-33-gtr/
A bit off topic, but I was reading a thread up here where you can fix the coilpack problems in the gtr's by putting high temp silicone on the hairline cracks that commonly appear on the coilpacks. Haven't done mine yet but seemingly everyone who has done this has fixed the problem.
its probably easier to fit the correct coilpacks and sell your old S2 stuff
it would be easy to sell the S2 stuff and coilpacks are a common failure in the skyline, so your best to fix it properly and be done with it
Its only a temp fix and also only if the insulation is the fault. If the coils broken down inside all the cleaning and insulating wont do jack
Same with an afm cleaning or re soldering 95% of the time will do jack once its f**ked its f**ked it will nearly always need a new element/hotwire
Edited by jjskyline79
Hi Ash,Better fix for you is URETHANE SEAL COAT,post-36964-1277096851_thumb.jpgpost-36964-1277101931_thumb.jpg
Hope this help`s you ,it`s a good fix & is not as messy as SILICONE ,& you can spray them any colour when done,
cheer`s Chuckie.
Yer good point, I'll just sell my old ones and buy some new ones :whistling:
Thanks
not sure it will work as the ecu will have a differant trigger for the inbuilt ingniters vs the external igniter
Not so sure about that dave, im pretty sure they are both the same trigger. As far as the ecu is concerned, both setups have external igniters. Actually im sure it can be done, as i recently wired an rb26 ecu to run a neo headed car
  • 4 weeks later...
So is there a wiring diagram for the R32 GTR igniter box or is it straight one to one plus the extra earth as on the igniter. It has 6pins (1 2 3 4 5 6)on the cold side and 7 pins (E 1 2 3 4 5 6) on the hot side
^ too true
just done mine then and tested and working perfect...
No need to sell my DIS-005's and buy DIS-001 for my 32 GTR
Have my R32 GTR running External Igniterless using DIS-005 Splitfires and its much cleaner looking to and saved my self a head ache and money buying/selling/swapping Coils only to be undone by the commonly Faulty R32 Igniter/Amplifier :woot:
Edited by krayzie32
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
