Hi guys,
I recently brought a r33 gtr and it has got the common coil pack problems as it miss badly and sometimes when cold it even stalls. My question is I used to own a r33 gtst s2 and I have a set of splitfires and harness from that, can I wire them into the gtr so I can use those splitfires and also it gets rid of the ignitor box thing?
Cheers,
Trav
https://www.sau.com.au/forums/topic/325477-puttin-s2-coil-packs-in-33-gtr/
A bit off topic, but I was reading a thread up here where you can fix the coilpack problems in the gtr's by putting high temp silicone on the hairline cracks that commonly appear on the coilpacks. Haven't done mine yet but seemingly everyone who has done this has fixed the problem.
its probably easier to fit the correct coilpacks and sell your old S2 stuff
it would be easy to sell the S2 stuff and coilpacks are a common failure in the skyline, so your best to fix it properly and be done with it
Its only a temp fix and also only if the insulation is the fault. If the coils broken down inside all the cleaning and insulating wont do jack
Same with an afm cleaning or re soldering 95% of the time will do jack once its f**ked its f**ked it will nearly always need a new element/hotwire
Edited by jjskyline79
Hi Ash,Better fix for you is URETHANE SEAL COAT,post-36964-1277096851_thumb.jpgpost-36964-1277101931_thumb.jpg
Hope this help`s you ,it`s a good fix & is not as messy as SILICONE ,& you can spray them any colour when done,
cheer`s Chuckie.
Yer good point, I'll just sell my old ones and buy some new ones :whistling:
Thanks
not sure it will work as the ecu will have a differant trigger for the inbuilt ingniters vs the external igniter
Not so sure about that dave, im pretty sure they are both the same trigger. As far as the ecu is concerned, both setups have external igniters. Actually im sure it can be done, as i recently wired an rb26 ecu to run a neo headed car
  • 4 weeks later...
So is there a wiring diagram for the R32 GTR igniter box or is it straight one to one plus the extra earth as on the igniter. It has 6pins (1 2 3 4 5 6)on the cold side and 7 pins (E 1 2 3 4 5 6) on the hot side
^ too true
just done mine then and tested and working perfect...
No need to sell my DIS-005's and buy DIS-001 for my 32 GTR
Have my R32 GTR running External Igniterless using DIS-005 Splitfires and its much cleaner looking to and saved my self a head ache and money buying/selling/swapping Coils only to be undone by the commonly Faulty R32 Igniter/Amplifier :woot:
Edited by krayzie32
    • It's not a dumb question. I was circling this idea myself. User error is always possible!
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
