Model: GXE Nissan Skyline
Year: 1989
Kilometers:Unknown
Transmission type: low kilometer 5 speed Rb20 box
Engine: Silver-top Rb20 Turbo
Colour: White
Modifications:
-silvertop rb20det conversion
-brand new Xtreme heavy duty clutch
-machined fly wheel
-vg 30 turbo
-hybrid fmic
-walbro 400 fuel pump
-thermo fan
-boost controller
-pod filter
-locked diff (mini spooled)
-rear slotted rotors
-monroe gt shocks
-lowered pedders springs
-front nolathene bushes
- 4 Ti rims with all 4 center caps
-new kenwood deck
-kenwood rear 6x9's
-kenwood front 6"
Roadworthy Certificate:No
Accident History: None
Asking:$4800ono
Contact Details: 0401261531, Nathan.
Other Comments: Unfortunately its time for me to sell my Skyline i've had a lot of fun with it but i have just moved in to my first house and need the money for house stuff, As it states above its an Rb 20 turbo which has been dyno tuned by morpower making 172.9rwkw @ 14psi, it looks pretty stock which is great because the cops dont look twice at it. the paint work needs some attention and there is a minor dent in the rear quarter panel but overall it looks good, It handles very well through the hills and slides with ease when you want it to.
Any Questions give me a call or just come have a look, NO TEST PILOTS.
Cheers, Nathan.
https://www.sau.com.au/forums/topic/325486-fs-r31-rb20-turbo/
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
