Ah k, doubled.
Does this new price incorporate all that "new and smart" technology?
Is there a link for more info?
P.S, come on guys......Dont just sign stuff willy nilly without knowing all the facts
Edited by r33cruiser
New licence's. The look of.
Page two of PDF says licence current renewal fee.
Old article saying cost will be $150 for 1 year
Qld licence cost
There is some articles. Personally I don't care if you don't sign. But nothing is more annoying then having someone say this isn't fair and yet does nothing about it when they had the chance.
I know some of the articles are old but if you took the time and clicked here you would get the same amount of info as I just got.
Linky link
Enjoy :D
Qld licence cost
Linky link
Enjoy :verymad:
the link you have entitled "old articale saying cost will be $150 for 1 year" actually says that the cost will be between $120 and $150 for 1 year, but it is also from feb, so to be taken with a grain of salt, especially when most newer articals say that it will be around $150 for 5 years, so i'd be more inclined to listen to them.
no one cares anymore aaron...
* ranga albino prime minister
* old bird leather face governor general
* Anna cant cut a sandwich Bligh
The big question now is 'Who is going to do the bloody dish's?
jks soz /end
aaaaaaaaaaaahahahahahaha, he thinks that because i'm from gympie i must be aaron under a different username. oh my lawd how that made me laugh. next time i see aaron i will have to tell him. sorry to dissapoint you, we aren't the same person.
bahahaha, oh lawd.........
who the hell is aaron? :miner:
see how much i dont care daryl
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
