R34 Gt - Turbo
Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
By DraftySquash · Posted
Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming) -
I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
