think north of $10k as a bare minimum to get it done properly. some spent $17-22k which is considered the norm for a well designed layout / install and tune.... e.g. APS kit
should have bought an R34 mate... :-) or M35 stagea... the turbos come 'free' in those... works out cheaper to swap
https://www.sau.com.au/forums/topic/325560-turbo-in-v35/#findComment-5301838
I already bought a v35. I love it. My folks helped me, and they thought R34's were too old. I'll buy one eventually...oh and a Ford Mustang with a blower...What? A guy can dream, can't he? I wonder if you could put a blower on a v35...with a hole in the hood, V35 Muscle/Tuner hybrid. Why oh why isn't there a pimp my ride in australia? Probably cause everything is banned in australia.
If there was, i'd just buy the body of a r34 and post a video to pimp my ride. Remake the whole thing. Fully sickness bro. More fuller then full.
Actually, come to think about it. I would buy the body of a nissan Gtr...I'll call up Jap World and ask.
Oh, btw...Brian from Just Cars...I don't have enough posts to reply to you yet, but you are f**king awesome!!! Peace
So, anyone else got anythoughts?
https://www.sau.com.au/forums/topic/325560-turbo-in-v35/#findComment-5302029
HKS does two kits, one is s/c and the other is tt kit... they're about $7-10k parts only ex japan not including install & tuning... if you can find someone to tune the supplied piggy back / replacement ECU.
APS have around $17k drive in drive out tt solution. Oh and if yours is 5sp auto you'll need have the auto rebuild
locally to withstand 500HP which is not included in APS' package. You see it will never be cheap to do FI on this car,
so best to leave it alone as N/A unless you are fully loaded with cash and got nothing better to do with them.
every country has their own different rule, unfortunately they can't just change the law for the sake of a bunch of 'pimp my ride' fans who felt left out. if you can't stand it, maybe take up a course/degree in teaching, and apply for an english teaching job in Japan and live there. car mod scene is more relaxed there... although they do still have 3-yearly road inspection called the 'shaken' which means they do still have some limits on how you modify your car before it's deemed unroadworthy and cannot be registered...
bye
https://www.sau.com.au/forums/topic/325560-turbo-in-v35/#findComment-5302072
When I was mucking around with mine I did consider a VQ30DET conversion. Decided to not go that way at the time, however, think it would be worth considering in future. Can pick up VQ30DET's for under $2000. Would have to look at sensor compatability......
https://www.sau.com.au/forums/topic/325560-turbo-in-v35/#findComment-5302117
Can't see why not given it is essentially the same block as the VQ. Aftermarket Engine management would be required but to purchase a VR you'd pay more than the market value of the V35 for a front cut
Edited by mosoto
https://www.sau.com.au/forums/topic/325560-turbo-in-v35/#findComment-5302223
I was considering doing this to a v36.
I use my V35 for work and it works well because its a sedan w/ CVT and just a plain good ride.
The reason i was going to go for the 36 is cause its got more powahhh to start of with and id be getting the manual coupe. No really point in having two of the same car either.
Spoke to a few people and the general concensus is that you'd be looking at about 20k to get it done right.
This includes: the kit, ecu, exhaust, cant remember if they incl brakes, and proper tune.
To me this would be AWESOME!
Since I do use cars for work i can claims stuff of tax, so I'm going to chat to my accountant and see what we can and can't do.
But the way I see it, $60-70k for a car that would be very quick and fun, w/ the skyline name and tradition, without the stigma attached to the hotplates would be pretty cool.
and it would just be really different.
Which is always good.
Hope that helps!
Cheers,
Tony
https://www.sau.com.au/forums/topic/325560-turbo-in-v35/#findComment-5302281
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
