  SKYRYAN said:
Just sparkplugs.
+1 also perhaps spray a bit of silicone lube in the coil pack where it sits on the spark plug, this will waterproof it and avoid any corrosion of the spring in the coilpack caused by moisture
https://www.sau.com.au/forums/topic/325563-coilpacks/#findComment-5302000
By Silicone lube......you mean the same as d!ck lube right?
Just making sure before i use my parents KY and find its the wrong stuff?
ok, serious now.... i been trying to find it, and keep ending up at adult shop o.0
https://www.sau.com.au/forums/topic/325563-coilpacks/#findComment-5313365
CRC silicone spray.
if u cant find it make sure u get one thats made to be used for electrical appliances and doesnt act as an insulator. infact i wouldnt even bother with the stuff to be on the safe side
Edited by jimmys-33T
https://www.sau.com.au/forums/topic/325563-coilpacks/#findComment-5317613
