I wasnt going to tell you all...
  • Replies 173
well ur all a pack of c**ts :D
uve put me off the mini completely! :P
but im still thinking of the GTI 180...
with all the features it comes with std it would be silly to buy anything else and insurance is stuff all.
however after going outside and looking at my other baby with the round taillights im starting to want to do it up :D
my head hurts
i dont want a street machine... i want a nice daily driver that i wont be hassled by cops for retarded things like H patterns and Tyre freakin weights and whatever other bs they want to come up with. I want something where i can get insurance at more than 2 places which dont charge u thru the arse.
You want to help the government achieve their goal but deep down,
my head hurts
For 45k you could turn that 32 into a bloody animal and have enough change to reupholster the interior in leather, pay insurance for 5 years, servicing costs, and any defect/fine that my come along.
With resale value (of a new car) keep in mind that as soon as your arse hits the seat you kiss 5-10% goodbye. After 5 years it'll come down to condition/km but expect to lose at least 40-50%.
yeah, nark is a poor confused man.. torn between a girls car and his beloved skyline.. which way will he go? will he find his testicles in time? will the ongoing love of his R32 pull him back with a passion? will common sense prevail? who will be the victor? only time will tell :)
i still think my suggestion is the most appropriate...
..actually I think his recent loss to his girl has given him an identity crisis, maybe if he has the girls car he can beat the guys out there? maybe this deepset and unknowledged resentment of this has finally driven him batty?? its all mixed up.. may i recommend some psychiatric care?
did you know that you can actually import any mini that was made up until 1999 under the new importation laws? lol
be a true techie n import your car...
but still a mini... omg u ARE AMST TEH GHEY...
are the L1's baggine the f**k thru u yet?
The new corollas and camrys feel like u r driving a bus. Their new dashboard design is shithouse
I agree. Was just a thought i had, if he could bare with a posbox for a while.
But hey, sounds like a bit of class is needed, so a posbox aint the best choice.
But the more you spend on the car, the more you may spend on insurance.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
