ok heres another question, if the stock boost is sposed to be 7psi,then if i put a exaust on it,will it creep higher without me doin anything, reason i ask is i wanna up the boost a little,to around 11-12psi,for high boost but when i drive around normally it sometimes reaches 10psi then drops back down to around 7psi, will setting the boost at 12psi be any difference? and is it really safe?
ive got 3" exaust,stock cooler,and pod filter and i always run it on optimax
https://www.sau.com.au/forums/topic/3256-standard-boost-on-rb20det/
With the boost bleed std boost was 12psi but for some reason with the EBC it is 10.6psi.?!?!?!
I'm guessing it was the restrictor type setup that was put in the bleed that I wasn't aware of.
Well according to the hand controller it is 10.6psi.
Could it be wrong?
The +7 line on the guage in the dash is supposed to be 13.5psi. when I set the ebc to 15psi the needle just starts to nudge over it.
are you serious the +7 is supposed to be 13.5psi?!?!?!
cos ive got a bleeder set to 13psi and its always maxing out the std guage but reading 0.9bar on the HKS one.....
however one thing ive learnt is not to rely on std guages so ill stick to reading the mechanical one i think...
And who said eeekkk.. Import cars are expensive to repair buy a ford/holden.
My old man.. :(
Funny thing is even if they were more expensive to repair I had a diff die in the VS V8 Manual at 90,000kms, a gearbox around the same time and the rear IRS chassis cracked where the diff is bolted on and the arse end dropped to the ground with the bumper touching the cement. :confused:
ok so thats $1200 for the g/box (which was still rattled after rebuilt), $1000 for the diff, $1700 to repair the chassis.
and that was with only 140rwkw. Imagine trying to put more power through it.
This all happened after about 9 months of owning the car. :burnout:
I've owned the R32 GTS-T now for a year or so and nothing has broke or damaged. :)
Guest nismogtsx
When i first got mine, I had no idea cause the standard gauge is really hard to read accuratlly. So i went and bought an Auto meter gauge.
I had 6psi standard. Then i spent al @@#$ load of money and now i can run 17psi. I can also go higher, but my gauge only goes to 20. So i call 17psi enough in dry conditions... LOL
I usually run 8 or 10 psi daily....
Then i pump it up to 15-17psi for dyno/circuit racing...
I was peaking 10psi on the dyno but it wouldn't stay there, it would settle around 8psi when she was dead stock.
It made 115rwkw dead stock on RPMS Dyno. & with the fuel pressure bleed it made 125rwkw but i was running BP Premium (95 RON) and if Tim advanced it any more it would ping :D
With timing & good fuel it should have made 130rwkw.
Exhaust a little bit of timing & fuel tune it made 152rwkw @ 12psi.
Then with 12psi still up top it made 156rwkw with alot more timing (25deg) and no pinging. :)
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
