I'm looking to buy some new 18 inch Work XT7's and need to know what offset and width I can go. I was hoping I could fit 9.5 inch as I think they would just fit with a little guard massaging.
I don't want spacers so I need to get this right first time. Any ideas guys?
Hey Scotty,
Spoolin and I worked out that the perfect fitment is a 9.5 with a +35 offset for the M35.
This will get it flush to the body without any rolling of guards and clear the front suspension arm by about 7mm. So no mods to the body and 100% no scrubbing.
It will also mean you get that deeper spoke pull on the XT7's that make them look soo good!
Im pretty sure the XT7 come in a 18x9.5 +38 which would be sweet with a 3mm spacer to give a little extra clearance on the front suspension arm (if it wasnt for that arm, we could easily fit 10.5 to 11" all the way round!
Edited by bbenny
Hey Scotty,
As Scotty stated he didn't want spacers, sucks that it is hard to fill the guards without having to add spacers.
If the suspension arm has 7mm clearance and he went with a +38 rim, that would reduce the clearance to 4mm. I assume this would be running too close for comfort?
Mmm 4mm is cutting it close as there is flex in those parts. I would rather push them out a bit more and rollll. ;)
Looks like +30's are the go then?
+ 30 will be fine, you will just have to roll the lip on the rear guard or just run a tyre size down so they are a little more stretched.
I just would be careful on the front guard.
Here is how a +35 sits on my car - as you can see its pretty flush up front. So +30 will sit 5mm further out, the rear will be fine with just a roll if needed, but the front guards are already rolled.
Honestly you will be fine with a stretched tyre.
  • 1 year later...
Sounds about right.
I provided that to Braid, and they said they'd suggest an 18 x 8 +40-42, but because they were a wider rim they'd sit out more and fill the guards a bit better.
So that's probably the way I'll go. A nice set of these:
http://samotorsporttyres.com.au/content/winrace-1
Sounds about right.
http://samotorsportt...ntent/winrace-1
+40/+42 would look crap. go minimum +30...
an 8 inch rim isn't that wide...
Agreed!
I ran AR-X 18x8 +40, but when I went to V35 18x8 +30; looks so much better! Consider +30 the absolute minimum; then get a little braver.
Also make sure you don't go too small on rolling dia, even 20's can get swallowed up in those big wheelarches if you go too low a profile.
Yeah you need atleast an 8.5+30 to near fill the guards.
mine were 8.5 +20
they sat awesome. 5 or 6 mm out the guard. worked well because of the ARX over fenders.
I'm getting tyres fitted Saturday. I'm looking at a 245/45-18 as there is a greater choice in that size. Also thinking of a 235/45-18 to get a little stretch to help clear the guards. Not that big of a choice in that size either. I like the fact the 245/45-18 is a little taller than stock to help correct the spedo a little. I'm assuming all m35's read higher than actual speed. Just hope they don't hit the guards on bumps or steering lock.
I'm looking at nexen n1000, anyone had any experience with these?
Edited by slippylotion
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
