I'm getting tyres fitted Saturday. I'm looking at a 245/45-18 as there is a greater choice in that size. Also thinking of a 235/45-18 to get a little stretch to help clear the guards. Not that big of a choice in that size either. I like the fact the 245/45-18 is a little taller than stock to help correct the spedo a little. I'm assuming all m35's read higher than actual speed. Just hope they don't hit the guards on bumps or steering lock.
I'm looking at nexen n1000, anyone had any experience with these?
Are nexens that much cheaper then say, KU31's? You should be able to get KU31's in that size for around 180-200 per corner...surely they're better then nexens?
Thats stupid. If you want ku31s, isn't there a sponsor on here that does them?
Otherwise call sa motorsport tyres, www.samotorsporttyres.com.au, and tell mark I sent you.
Agreed!
I ran AR-X 18x8 +40, but when I went to V35 18x8 +30; looks so much better! Consider +30 the absolute minimum; then get a little braver.
Also make sure you don't go too small on rolling dia, even 20's can get swallowed up in those big wheelarches if you go too low a profile.
ARX Rims are 7.5 wide, but I agree 8" wide +30 would fill the guards nicely.
Hmmm, I'm sure they're 18x8"; I never measured them though.
My 350GT rims are 18x8" and the tyres were stripped from the AR-X rims & fitted to the 350GT rims; fitted exactly the same.
Same sidewall angle; everything.
Edited by Daleo
What brands do SAMotorsport tyres sell?
Check out their web site. They can get just about anything, but bread and butter is federal, hankook and silverstones.
I dont understand why people buy nice new wheels and put shitty nexen/nankang/generic crap on them. Grip ftw! :thumbsup:
I'm looking at 245/40-19's.. Kuhmo KU31 for $205 a corner or Yokohama EP400 for $230.
Paul, I really don't know my tyres but how about Kuhmo KU19's? http://www.ebay.com.au/itm/18INCH-245-45-18-kumho-ku-19-100y-/130572666135?pt=AU_Car_Parts_Accessories&hash=item1e66bcc517
I'm really happy with the ku31 on my 180sx. Im not sure how quiet they are though as the car is quite loud.
I think I'll just hunt around for the cheapest price on a ku31.
are these better or worse....Please note that they are 19's
http://www.tirerack....ark=1&x=20&y=15
My preference is to go for these this time around though!
http://www.tirerack....romCompare1=yes
anything is better than the shit I had on there!
They are the same (KU31). Nice price for 19's, shipping does kill the savings a little though....
WTF Craig? Planning a move to Canada in Winter? Those are SNOW Tyres!!!!domokun.gif
I have the Extreme Contact DW...
For anyone considering tirerack - My shipping was $270 shipped to my door. 4x 19" tyres. Sure is a great service.
Oh and KU31 > KU19.
KU19 comes as OEM on korean shit cars...
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
