M35's Wheels. What Wheels Do You Like On Your M35?
http://photos-f.ak.fbcdn.net/hphotos-ak-snc6/190611_1943516947317_1224295443_4398956_8279466_n.jpg
This is my Gf stagea as it sits at the moment
There weds kranze cerberus ii in 19s
Width I'm unsure as the same as ofset ,
Tires are 19/235 35 on the front
And 19/265 35 on rear , tires are also look fairly stretched,
Looking the goods there!
I'd be willing to bet those staggered tyre sizes are the root of you driveline shudder.
They're a no go on these cars...
Size is up to you, but they have to be the same sizes front and rear.
Even theoretically perfectly matched rolling dia staggered sets seem to cause issues with the ATESSA system.
If you can; fit a set of matching dia wheels/tyres, and see what happens.
I always found this a little strange, by this reasoning adjusting the camber on a car, even if its not by choice (lowering) would change the amount of tyre contacting the road and thus change the width and more than likely the rolling diameter ever so slightly...
I have also seen plenty of GTR's running staggered widths in the past, is there something about our cars that makes this an impossibility?
Mike.
Mike.
I have to say I agree. GTR's seem to get away with it fine, I've even seen Evos with 9.5" wide rims front, and 9" rear, albeit with the same size tyres (apparently gives better grip through corners), but when I had slightly different tyres on my C34 Stagea, it "bucked" from the get go. I won't be trying it on my M35..
Hey Wagon boy, looking nice! Did you get the wing fitted after or was it already there?
He already had it; but he's just minding for me until Sunday...:ph34r:
Bloody Nismo; why can't they just make something that I DON'T want?:spank:
Most wings are "not suitable for ARX" is this correct?
No.
All Nismo add-ons state "not suitable for ARX" for some reason, even though you can fit the speedo, suspension, exhaust, wing etc just the same as with an RS or RX.
Where there is a bit of a problem is with front and rear bumpers and side skirts due to the ARX and Axis flares.
  • 1 year later...
Is the rolling diameter the same? It's a question I have heard debated back and forward several times.
Someone with a tape and this type of setup care to share?
 Share
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
