M35's Wheels. What Wheels Do You Like On Your M35?
  • 3 weeks later...
I'm going to be a bit boring here, but I like the stock 18's, on my Axis. Pretty certain they are AR-X stockies, not Axis stockies though.
Ideally, I'd like to get some thicker rubber, a bit of low, and possibly some white lettering on the tyres. I think that would look kinda cool.
Edited by Shazbanger
I ran AR-X rims on mine for a while; they look good,
They need about a 10mm spacer, and 245/45/18s.
  • 2 years later...
Bit of a shit photo but was from the boys weekend up to sydney, had to get the other cars in shot as well (the 2 navs)
12108072_10153376277737946_4867148141037
Weds Kranze Bazreias, 19x8.5 +41F 19x9.5 +43R with a 20mm spacer all round to clear the brakes and get them out of the suspension.
245/45/19 Nittos all round and no issues with the AWD keeping everything in check.
End goal with the wheels is new lips on the 8.5 pair to bring them to 9.5 square, should push the rears to +10ish with a smaller spacer/+20ish no spacer
Edited by BIGZED
  • Like 1
20x10 all round +35 3mm spacers up front 255/30/20
Not rubbing at all. Needs to be this height for the camber to pull them underish the guards.
How much camber is this running?
I have been looking for wheels for a while now but offset is the biggest concern i have.
Plan was to run 19x 9 front and 19x10 rear
245 and 265 rear with 5 sidewall difference to maintain rolling diametre within 1% from memory
I like the idea of different offsets and different widths it certainly looks good. But i remember what my old man said to me a few years ago how are you going to rotate wheels to keep wheel wear even
I never rotate wheels. My theory is that they wear faster that way and it means you have to buy 4 at a time whereas I prefer to spread the financial burden.
They will wear at exactly the same rate as they were going to wear at.
Defraying the financial burden is understandable, but also more manageable when you regularly rotate tyres, as you have plenty of advance warning.
The advantage in buying 4 at a time is you actually have some buying power, and that has saved me almost the cost of a single tyre in the past.
You don't get that level of discount when buying 2 at a time.
As for people who buy one tyre at a time; they just make me mad...
  • Like 1
Running stock camber for the height.
Rear wheel could easily go 10.5 +42mm
Front only has 1-2mm clearance to the inner upper arm with 10" +35mm and 3mm spacer. So perfect would be:
Front 20" x10" +32
Rear 20" x 10.5" +42mm
I wanted to be able to rotate. Ozzy tyres do custom offset for free. If you get these same Directional wheels make sure you state that you want directional. Ie different left and right so they all lean the same way.
Matt
  • 1 month later...
So I got these over the weekend, they are ANZ "Velvet" (yes, velvet) in 18x8.5 +35.
Two are in good nick, two with a bit of rash that will need filling.
Keeping in mind these are going on a red NM35 which will also have a set of R33 GTST front callipers I am rebuilding, here is what I am thinking:
Patch up the rash with filler, touch up with "chrome" paint and give them a polish, callipers black or colour coded red. (my least favourite idea as they will look ratty bling).
Patch the rash, matt or satin black rims, gold or red colour coded callipers. (probably my favourite, brembo gold, black rims, headlights, grill etc).
Patch the rash, gunmetal/charcoal rims, gold or red colour coded callipers.
" " " , gold rims with black or red colour coded callipers.
Only going to paint as I don't want to spend too much on these nasty rims with powdercoat or plasti-dip.
Whichever way I go I will also fill in the "Velvet" logo and ditch the "ANZ" caps.
All opinions/other ideas will be greatly..............ignored, especially if they are, "hey mate, they're rubbish, save up and buy some decent rims you cheapskate!"
post-135423-0-16298700-1449495531_thumb.jpgpost-135423-0-32045700-1449495608_thumb.jpgpost-135423-0-80420700-1449495632_thumb.jpg
  • 3 weeks later...
Oh so tempted to order some Varrstoen's ES6's myself... do some rear guard work to fit as wide as I can seeing as i don't have to care about an Altessa anymore :)
must...
resist....
:P
(that reminds me i should sell some of the parts i no longer need...)
Edited by Beregron
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
