Since the other thread turned into a free-for-all whorehouse which never got updated, let's start again. I'm also breaking parts down into catagories for easier finding.
Use your browsers search function to search this page, usually its CTRL+F.
Please, for the love of God, keep the chit chat out of this one, if you have questions, search the forum, if you still have a question, post a thread.
This took me a few hours to write up and filter out all the bullshit, I have removed SOME parts from the original list to prevent confusion, I have also ADDED some parts to the list, and specifically added alot of AWD parts compatibility.
As usual, post CONFIRMED parts only, please state exactly what it is from, and what it will fit.
Link to source thread, here:
http://www.skylinesaustralia.com/forums/A3...ist-t93523.html
Confirmed parts list for:
A31 Cefiro (1988 - 1994)
C33 Laurel (1988 - 1994 (LHD 1988 - 1997))
INTERIOR / ELECTRONICS
Air-Con Dryer Condenser
A32 Maxima/A32 Cefiro (1995-1998)
Boss Kit
S13 Silvia (1989-1994) (NON-HICAS Model)
Centre Console
(HERE: http://www.skylinesaustralia.com/forums/Ce...centre+console)
R3x Skyline
Handbrake Lever
R32 Skyline (1989 - 1994)
Handbrake / Gear shifter leather boots
R32 Skyline (1989 - 1994)*
*requires slight modification, unknown
Power Window Mechanism
R32 Skyline 4 Door (1989 - 1994)*
(Suggested the rears may not work, discussion, HERE: http://www.skylinesaustralia.com/forums/A3...6#entry1966766)
Genuine Nissan Part Number (Cefiro Specific) (Driver's Side)
# 25424-71L00
Power Window Relay
Bluebird (unknown generation, year, "its the one with the SSS variant)
Seat Belts
A32 Maxima (1995 - 1997)*
*After 1997, A32s came with pre-tensioners
Seats
Front
R33 Skyline (1993 - 1998)
S13 Silvia (1989 - 1994) (requires slight modification to holes on rail)
Rear
R32 Skyline 4-DOOR ONLY (1989 - 1994)
DRIVETRAIN / ENGINE
Alternator
VL Commodore (1986 - 1988) (RB motors only)
R31 Skyline (1985 - 1989)
Air Intake Box w/ Cold Air Snorkel
Air Flow Metre
Z32 300ZX (1989 - 2000)
Same plug and direct fit, Naturally aspirated models will equal a direct fit, however the twin turbo models will require a fuel remap / tune. T/T models provide best known signal to ECU and are very sought after
Cradle
RWD Cefiro/Laurel
Front - N/A
Rear - R32 Skyline (1989 - 1994)
AWD Cefiro/Laurel
Front - R32 Skyline GTS4/GTR (1989 - 1994) *
Rear - R32 Skyline GTS4/GTR (1989 - 1994) *
* This also acts as a 5 stud hub upgrade, different pattern diff, etc
Crossmember
(AWD - R32 Skyline GTS4/GTR)
Differential
RWD
R180 (Open Centre)
R200 (Limited Slip)
Drive Shafts
Exhaust
Manifold - RB20DET Standard item
Dump Pipe - RB20DET Standard item
Cat/back - no known direct replacement
Gearbox
Replacement
RWD - RB20, R32 Skyline GTST (1989 - 1994)
AWD - RB20, R32 Skyline GTS4/GTR (1989 - 1994)
Upgrade (info on what is required, HERE: http://www.skylinesaustralia.com/forums/Rb...ff-t103164.html, and HERE: http://www.skylinesaustralia.com/forums/Rb...4#entry1898084)
RWD - RB25, R33 Skyline GTST
AWD - RB25, R33 Skyline GTS4/GTR (1993 - 1998)
Gearbox Crossmember
(http://www.skylinesaustralia.com/forums/Gearbox-Crossmember-t145192.html)
RWD
Manual - CA/SR Manual
Auto - R32 Skyline MANUAL (1989 - 1994)
AWD
Unknown
Half Shafts
Intercooler
Front Mount
No known direct fit, usually requires cutting+shutting of reo bar (which is illegal), and R32 Skyline piping will fit with some cutting
Side Mount
Skyline R34 GT-T (1998 - 2002) (Requires some slight modification)
Radiator
Radiator Shroud
Speedo Cable
Water Pump
Standard RB Item
SUSPENSION / HANDLING
Brake Calipers
No known direct replacement, SR20DET brakes may fit if you use rotors as well.
Brake Lines
Brake Master Cylinder
R32 Skyline (1989-1994)
Brake Pads
Bendix Part Number:
DB1144 - REAR
DB1485 - FRONT
Handbrake Shoes (http://www.skylinesaustralia.com/forums/Handbrake-Shoes-t132015.html)
Skyline R32 (1989 - 1994)
Skyline R33 (1993 - 1998)
Silvia S14 (unconfirmed)
Brake Rotors
No known direct replacement without redrilling other models
Clutch Master Cylinder
Clutch Pedal Box
Coilovers
RWD Cefiro/Laurel - S13 Silvia (1989 - 1994) * *
AWD Cefiro/Laurel - R32 Skyline GTS4/GTR (1989 - 1994)
*(stronger spring rates recommended to conpensate for extra weight of longer chassis/RB motor)
*(be advised that distance from strut tower to knuckle assembly base is SHORTER in S13, so if you can, aquire longer bases if ordering S13 specific coilovers, and that standard S13 springs/shocks usually sit the vehicle below legal height)
Handbrake Cable
R32 Skyline (1989 - 1994) *
* Hit and miss again, some claim only 2 door, some claim only 4 door, some claim neither fits.
Might be best to get one custom made for around $100 - $200 mark.
Lower Control Arms
Radius Rods
Steering
Box
S13 180SX (1989 - 1994)
Rack & Pinion
Strut Brace Front + Rear
RWD Cefiro/Laurel
S13 Silvia (1989 - 1994)*
AWD Cefiro/Laurel
* Hit and miss, if possible, find a brace that runs back and along the firewall, as some braces will NOT clear the RB motor (or if they do, not allow the bonnet to close)
Swaybar
Replacement
(inc. brackets, bushes, bolts, links, etc)
Upgrade
R32 Skyline GTR (1989 - 1994)
Not confirmed for AWD models
Tie Rod Ends
(http://www.skylinesaustralia.com/forums/market-Tie-Rods-R32-t135991.html)
A32 Maxima/Cefiro (1995 - 1998)
Wheel Hubs
RWD Cefiro/Laurel
AWD Cefiro/Laurel
R32 Skyline GTS4 (1989 - 1994)
BODY
Door Hinges
Front Spoiler Lip
(http://www.skylinesaustralia.com/forums/Cefiro-Front-Lip-t124902.html)
S13 180SX (1989 - 1994 (turned upside down)
Fuel Lid Spring
U12 Pintara (1989 - 1992)
Sunroof
MAINTANCENCE / SERVICING
Coilpacks
CA18DET / RB20 (Red-top)
Oil Filter
Standard RB item
Fuel Filter
Standard RB Item
OTHER
Stereo Wiring
http://www.installdr.com/Harnesses/Nissan-Wiring.pdf
RB25DET Engine Upgrade
http://www.skylinesaustralia.com/forums/Rb...ro-t128658.html
Wheels and Offset
http://www.skylinesaustralia.com/forums/A3...up-t143026.html
http://www.skylinesaustralia.com/forums/Ce...et-t131425.html
Fuse Box Layout
http://www.skylinesaustralia.com/forums/A3...amp;hl=fuse+box
https://www.sau.com.au/forums/topic/325614-parts-thread/
  • Replies 71
Posted Images
AMMENDMENT:
Air Flow Metre
Any VG30 AFM will fit, not just Z32...so J30 Maxima's and a few others also fit and are N/A, so no retune is required, and they're easy to find
More Parts:
Roll Cage
Cefiro and Laurel and interchangeable, not much else fits.
Be sure to use either sunroof or non sunroof accordingly, so it fits right and pushes up/outwards, otherwise it defeats the purpose of having a cage fitted.
Rear power Window Amps
U13 Bluebird (1991 - 1997) *
Different mounting brackets....swap with the Cefiro/Laurel ones and you're set.
Wiper Relay
EXA - unknown generation/year
Swaybars for the Cefiro specifically can be purchsed from Selbys (http://www.selbys.com.au/)
Nissan Cefiro 88-03
F Swaybar-h/duty Blade adjustable SNF702A 27mm Replacement type
R Swaybar-h/duty Blade adjustable SNR26A 22mm Replacement type
R Swaybar-X h/duty Blade adjustable SNR26CA 24mm Replacement type
Sunroof Switch / Map Light assembly
J30 Maxima (1989 - 1995) *
* Wiring is different but module fits...rewire it and you're all good to go.
Windscreen Wiper Signal Amplifier Module
Honda Legend - generation/year unknown.
O-Ring Seal for Fuel pump
Nissan Part Number NI-17342-01A00
ABS Module
S13 Silvia SR20DET (1989 - 1994)
Part Number: 47600-71L00
Please incorporate into original post.
https://www.sau.com.au/forums/topic/325614-parts-thread/#findComment-5302580
cat back exhaust = aftermarket r33 , a couple of the hangers are slightly out of place but length and angle are identical
the complete hand brake set up from r33 also fits but there is little adjustment .
Z31 afm also is a direct bolt/plug in (purple sticker)
Edited by toffy
https://www.sau.com.au/forums/topic/325614-parts-thread/#findComment-5302904
also: Alternator: r33 rb25 fits but you must change the wire connector to a larger hole type
https://www.sau.com.au/forums/topic/325614-parts-thread/#findComment-5303061
  • 2 months later...
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
is the R32 brake/booster servo really a direct fit?i know it fits as such as i have fited one to my own but just left off the booster there is a brown box with a wire which plugs into the original cefiro booster,but there is no connection for it on the r32 item?whats this brown box for?
https://www.sau.com.au/forums/topic/325614-parts-thread/#findComment-5670356
^^ No idea.
Burnsie. Rear strut braces are a straight fit, some front braces for S13s don't go onto Cefiro's because S13 braces obviously accomodate for SRs and CAs, so sometimes thye won't clear the larger RB20 throttle body and BoV. It's a hit and miss. Best bet is a Cusco or some kind of 3 point brace that runs back and along the firewall, rather than straight from strut to strut.
https://www.sau.com.au/forums/topic/325614-parts-thread/#findComment-5670485
^^^ i would like to find this out,The brown box is obviously got something to do with the booster as the wire coming off it plugs into the booster but id like to find out its function and see is it need/does it effect performance off the booster if an R32 unit is fitted hmmmmmmmm...also im new hear,im johnny from ireland,i have a A31 rb20det cefiro with quite a good spec its undergoing a bare shell rebuild at the minute,il post up an intro with some pictures :)
https://www.sau.com.au/forums/topic/325614-parts-thread/#findComment-5670547
32 gts4 and gtr coilovers fit the AWDs. Gtst coilovers no good for fronts on rwd and awd completely different.
That brown box is controller for brake warning light.
When fluid is low or pressure is dropping under braking the handbrake light comes on.
Thats how/why its linked to the BMC sensor plug. Plug for the BMC should be the same for all Nissan BMCs.
Edited by Nic_A31
https://www.sau.com.au/forums/topic/325614-parts-thread/#findComment-5671397
Thats great thanks for that,also has anyone a step by step wireing diagram for a A31 ..mine is under going a rebuild and there is a lot off junk wireing there from stuff that has been removed.discared and id like to get rid off all this uneccessery wireing :) cheers..also can someone point me to the newbies introduction section i cant seem to find it?cheers
https://www.sau.com.au/forums/topic/325614-parts-thread/#findComment-5672509
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
