Advice on dragging...
95GTST
 Share
Hi guys,
I'm putting my car in the Warrnambol drags on Feb 8th, and was after a few tips from those who have dragged before (rpm launch?, etc)... Was also after a rough estimate on what time I should get, here's what I've got;
95 R33 GTST
FMIC
3" Full turbo-back exhaust (heat wrapped)
boost controller will be set to 15psi
loaning a set of 17" semi-slicks for the day
stnd suspension
k&n panel filter
Will also have new Apexi SAFC & bov by then too. Car will be dyno'd and tuned.
Frineds of mine hv R33 GTST, most of them only able to launch @4500rpm on street tire, but i think simi slick should be able to launch 6000rpm, I forgot ur car is rear wheel drive :wassup:
after a few tips from those who have dragged before (rpm lunch?, etc)....
I suggest about 5000-5500rpm and slip it off the line with a little controlled wheelspin...
As for lunch, I recommend a light proscuitto, pecorino and rocket salad drizzled with truffle-infused extra-virgin olive oil with a nice glass of 1981 Penfolds Members Vintage Reserve Pinot Noir to cleanse the palatte.
95GTST,
The conditions (track surface/temp etc...) on the day/night will dictate what launch rpm works best. Your clutch will also be a big factor in how best to get your car off the line. Merli's suggested rpm & technique is a good way to go. Very harsh on a stock clutch though.
As for predicting how you go? I'd be happy with mid to low 13's (~105-107mph) with your current mods.
No no no Andrew you've got it all wrong. He actually wants to know how fast to eat his lunch (rpm lunch) kind of like a bites-per-minute sort of thing ;)
If he is using the standard turbo and with semi-slick tyres i'd be aiming for a 13.0-13.4sec pass (thats if the standard turbo doesn't blow up on 15psi).
:Bang:
Dont be scared to practice launches before you go out. A very quiet country road is good for 0-100 practice. The track will be different but if you have never done it before its good to get a feel on what rpm spins or bogs down. My car felt good on the street tarmak but at the drags i was getting massive tramp problems through worn lower control arm bushes and stuffed viscous lsd. When staged i hold the handbrake on dial revs and take up the clutch pedal slack, then engage it on the second last amber light releasing the handbrake at the same time(jap style).Hope you understand lol..
On regular sh1tty street tyres i launch off of the handbrake as described immediately above. On semi's, i've recently discovered that i get better 60' times (consistently 1/10th sec better), by doing a great big smokeshow first - then launching with a small amount of clutch-slip to control the wheel-spin through first gear.
Merli, who can afford the bling req'd to guzzle 1981 Penfolds Members Vintage Reserve Pinot Noir every day?!?!?
Oh and if you have a std computer, good luck laucnhing from 8000rpm. ;-)
Adrian
  • 4 weeks later...
hahaha i might be able to 8000rpm, but fat chance ill do that.
i leaunch mine at about 3500, but i hold it at 2500 at the staging lights till it starts to drop then as soon as it gets to the 3rd light down i give it half throttle and start slipping the clutch out pretty fast while moving my right foot fully to the floor, which pretty much makes it 3500 at time of clutch biting.
this allowed me to do a 13.550.
stock turbo, stock cooler, cat back exhaust, 11.3psi, 255 wide tyres.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
