Getting rid of all the rest of my skyline parts i have in the shed
just want it gone as i have no use for them anymore as i dont have my 32 anymore
parts are in the northern parts of vic (50mins drive from cbd)
but can post for extra on the smaller parts
Greddy black turbo timer and r32 harness - $70
Cyberstork cluster dials (sit over existing dials) in white with red dials for 32 gtst and gts - $40
32 sedan front seatbelts and top piller trims - $50
white 32 sedan standard rear bar - $20
standard cat (hollowed) - $10
standard 32 gtst intake pipe (modified with a metal middle section so it doesnt suck close) - $20
series 1 32 sedan tailights in gc - $60
32 coupe rear seat complete faded at top - $50
32 passenger side front velour seat - $50
32 front seats in cloth (both, will need a clean) - $50
have a few windows from a 32 sedan (fronts/rears) - $40 whatever is there, should be 1 whole set
also have standard intercooler, CAS, cam gears, wiring for doors on sedan and standard rb20 gearbox shifter
and a set of r34 25gt standard wheels painted pressure can black with crap tyres - $80 the set
only whats listed is for sale
pics can be supplied for requested parts
Nick
https://www.sau.com.au/forums/topic/325623-garage-cleanout/
    • On the compressor side it looks like the best, if your head setup will support doing 100-110lb/min at 30psi-ish boost.   The G45-1350 compressor looks ideally better if you need closer to 40psi for it, given both the G40 1150 and G42 1200 look like they'll be around the 100lb/min mark at 35psi and dropping from there.   Bear in mind the turbine sides are all different between those three turbos, so that COULD be an influencing factor for how they all perform in the real world as well.   Not sure if you've made a conscious decision to only look at Garrett or not, but at least on paper the XRE7169S matches or beats those other three at everything from 30psi up and just going from wheel size alone likely to be at least as responsive as the G40 1150 and seem to behave closer to G42s in terms of turbine flow.
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
