I'm bored today so I felt that I had to post something totally irrelvant to cars and the like.
How many Vic SAU goers visit Hard Kandy on a Friday night?
I'm a reasonably newbie at going but I have nothing to say about it besides I'm hooked!!! :rave:
The first time was just before Xmas and then I've been the last 2 weeks running and it has gone off in a big way everytime.
I was kindly introduced to HK by Wardest and I must say that it one of the best things I have ever experienced.
It gives me something to look forward to during the week, especially today as not only is "Hump Day" but it is only 2 sleeps until the next Kandy session!!
Unfortunately I won't be there this Friday due to other committments but I will definately be there next Friday and other Fridays to come.
https://www.sau.com.au/forums/topic/32563-hard-kandy/
  • Replies 65
booooo to u too!!
:D
i only went once when i was chilling down outside with my cousin at cage... went in for about 20mins and came str8 back out again... too many heros with their shirts off and dancing like gorillas.
https://www.sau.com.au/forums/topic/32563-hard-kandy/#findComment-652632
mmm, DJ_Lethal and i go to Billboard every Sat night (not the Hard Kandy night)
But out bartender (yes... we know him by name we are there so often) says that friday nights go off just as good.
In a hardcore way.
So i'm planning to go one night soon and check it out.
https://www.sau.com.au/forums/topic/32563-hard-kandy/#findComment-652664
Bugger Kandy and the Cage - go to the Mansion! (Now Im showing my age!)
Actually if you are getting into Kandy/Bubble etc try the Frantic events (held at rOOm680 every now and then on a Friday. Used to be held at different locations - Palace, Dome, Capsule) Best Hard House nights out in Melb by far (or used to be when I was clubbing) Free super-doopers rock.
http://www.frantic.com.au/fl_index.html
https://www.sau.com.au/forums/topic/32563-hard-kandy/#findComment-652667
Admittingly, I haven't been to Bubble or Bass Station yet but am intending on going in the very near future.
For the timebeing though, there is no alternative to the Kandy.
I have met some people who have been going for over 3 years and they reckon that it is simply getting better as time goes on.
Scott Alert is a dead set legend and one of the best DJs I have ever heard anywhere!!!!
I have found Nirvana and it's name is Hard Kandy!!!
Oh and BTW, Nark, for the fact that you are leaving the Skyline fraternity, noone is listening to you anymore :whip:
https://www.sau.com.au/forums/topic/32563-hard-kandy/#findComment-652751
Hey leewah this is from my gf :D
"hehe how old is leewah to only just now find out about kandy ? it was good when i went but hopefully he will move on lol to some hardcore stuff not that there is any good clubs like cage anymore.. some one should buy him a ticket to a rave and open his eyes up :P"
lmao u go girl
https://www.sau.com.au/forums/topic/32563-hard-kandy/#findComment-652829
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
