im looking to do some turbo mods fairly soon....
so far ive looked at a kkr430 (heard mixed stuff bout them...
ive heard they will hit full boost at around 3k on a 25... (seems a little low to me?)
a garret 3076r... is this going to be too big for street... do i really need somthing this big... also not tooo cheap..
or a highflow of my stocker to save rooting round...
feedback from ppl whould be great :P
https://www.sau.com.au/forums/topic/325660-feedback-on-your-turbo-upgrades/
Do you want response or do you want the max power your stock internals can handle
Answer that question and that will help determine which turbo you pick.
I went the gt3076r .82 IW. Will push the internals to the max, but you do loose some response
Allow relistically $3k for ALL the parts required to fit one of these.
I went kkr type on the 30 because I wanted cheap and responsive.
the turbo I have is pretty small for a 30, makes 250kw@16 psi at about 6000rpm and chokes after that.
like Darrin said it really depends what you want.if you are after the most efficient cutting edge stuff, go the garrett ball bearing option
Ok, I'm unsure where to aim
supporting mods are
- greddy profec b spec 2
-3" turbo back
-fmic
-z32 afm
-seimens 620cc injectors
-apexi pod
-shift kit
... After turbos in I'll put z32 and inj in to be nisstuned
I'm thinking it's either hiflow or kkr, what would I expect to pull with either turbo at 14 15 psi?
I'm after response I rekn... How often to you spend at 5500+ rpm on street lol
what would pros and cons be for both?
Both going to be under a grand to get on,
kkr doesn't gave the best record am I not mistaken?
The big thing I found after my turbo upgrade was the need for a higher stall converter. The auto box really excentuates the increased lag over the stocker. I know track times don't really matter to some, but I was quite stunned when I went from a 1.8 60ft to a 2.3.
this will only effect 0-100 time not overall kw tho yeah?
Sorry about that chef, I saw the 260RS in your profile.
The upgrade path is pretty straightforward I reckon a hi-flow is probably the most logical step as there is the least time messing around.
GCG hi-flow, Hypergear Hi-flow, HKS GT-RS, HKS 2835ProS, GT3071, GT3076 are all options each with its own pro or con either based on price or result. Some will need additional parts like dump changes, spacers etc.
I may have a HKS GT-RS kit 2nd hand for sale or a HKS 2835 ProS kit (with a brand new cartridge installed) once I decide which one to keep.
To an extent, yes.
Some people, in the LS1 community, have reported small drops of a few KW's on their dyno figure when upgrading to a higher stall. But really, a dyno is a tuning tool and a difference of a few KW's may just be the price you pay for abit more driveability.
I have a kkr430, it's winding up about the time the stock one does but hits full noise maybe 3500?
I find it a bit laggy, though that may just be attributed to my way-too-large throttle body, but on a smooth acceleration it melds you into the chair quite nicely.
As for power, I've wrangled 270bhp with all the supporting mods and an exorbitantly priced ecu.
Adam, a HKS 2530 would be just what you're looking for IMO.
Very responsive and about 180 awkw @ 10psi with more boost to wind into it, with your kind of mods. I've got 204awkw coming out of mine with 11psi (manual trans) ... about to wind it up to 16psi when I get it on the dyno soon with an aim for (hopefully) the 240awkw mark.
Just in time for the Time Attack next month :)
You still haven't stated your target power but since you have the Z32 afm and the massive injectors you may as well go for 260 -270awkw.
In my opinion the KKR and 2530 won't hack it.
On a budget Hypergear will build you a turbo to do the job or the GCG highflow will make it or if you can get Wolverines 2835 pro S that will do it. If I were in your position again I would buy a GT3076 lowmounted ...that would do the job with capacity to spare.
p.s if you blow the auto people converting to manual generally end up giving their auto boxes away unless they have been modified
pps get a GTR manual box later!
I wouldnt do the kkr .. . .. perhaps on a r32 hacker but not the S2 stagea.
a secondhand 1grand hks-2530 / new $1300 garret gt2860 or gt2871 equivalent would be fine for 230awkw with great response.
fueling would be fine with the injectors/z32/nistune.
**** just noticed - no aftermarket fuel pump listed - what have you got in there atm?
to max out that fueling the GT3076 would be perfect as per above comments from kiwirs4t
perhaps come for a drive with me to see how the 3076 feels. it isnt that laggy tbh, but enough so to notice. she's a heavy car tho
perhaps with a stall converter as mentioned it wouldnt be noticeable?
as it is I really enjoy the gt3076 "highflow" with a flowed head & poncams - Id say with a dirty-30 bottom end it'd be the bees knees
Im nowhere near maxing out the turbo from Bill at ATS, another 10-15% in it left, due to the Toshi remap ecu / Aem Fic-8 holding it back as well as sticking to 450cc S15 injectors.
I'll have to wait for the rb25 nistune option (if it ever comes out, or grab a Vipec ECU) and some 660cc injectors to make the most of the turbo Ive got.
Plus some gearbox work, however as-is the box is fantastic! service & shift kit from MV autos for now.
So, anyways, for you.......
Nistune, fit injectors and z32 afm, fit HKS-2530 or Garret GT2860 for excellent zippy response, bit restricted uptop of powerband, 230-240awkw is possible
fit HKS 2835 or Garret GT3071 for perfect mix of response and power, 250-260awkw is possible
fit Garrett GT3076 for more topend, 270awkw is possible on unopened Neo motor.
Once you get to the 250kw mark, think about a good thicker multi-layered steel headgasket, and excellent oil & water cooling, and a Bosch fuel pump
alrity...
not sure i could push anymore than say 260 at all 4s out of the stock auto trans anyway would i?
i do have a walbro 255lph fuel pump sorry forgot him!
i think the PU version of hypergears highflow will be the option i take... .82 rear housing (.64 on normal highflow)...
shouldny be too laggey i dont think... im more after mid-range tho i think. lets face it how often to we spend at 5500+ rpm... for the sake of a few top end kw's and boost hitting at 750rmp lower... maybe the .64 option is better?
also being in adelaide we have ALOT more cop dramas than the rest of the states.... keeping it "nissan :whistling:" would be a wise path i think.... plus it will still get a decent $ when i decide to move on.
Edited by chef_stagea
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
