im looking to do some turbo mods fairly soon....
its for the stag (neo 25)
so far ive looked at a kkr430 (heard mixed stuff bout them...
ive heard they will hit full boost at around 3k on a 25... (seems a little low to me?)
a garret 3076r... is this going to be too big for street... do i really need somthing this big... also not tooo cheap..
or a highflow of my stocker to save rooting round...
i wona run around the 15psi mark... nice and safe and not too much for street :P
feedback from ppl whould be great :)
https://www.sau.com.au/forums/topic/325661-turbo-upgrades-what-to-do/
  • Replies 54
Posted Images
Depends on what rear housing you get, I have a 0.82 on mine and it takes awhile to spool, but when it hits boost, it can be a bit of a handful but as you have AWD, it should be alright. If you want something a bit more responsive, maybe look at a smaller rear housing for the 3076, or maybe get a 3071...but for good response and power, I suppose you cant beat a Hi-Flow.
Go for a Garrett. Sooooo many options, amazing quality, lifetime warranty, well worth the extra coin. You wont be disappointed.
One thing I can suggest man, is that choosing a turbo based on a target boost level is the most backwards way I've ever heard of...
15psi from a 2860 is a sh!tload less air than 15psi from a 3582...
How much power do you want? Choose a turbo that's gonna place your power figure, smack in the middle of the meat of it's efficiency range, take note of what boost it should be putting out, check out the Garrett website for the catalog and compressor efficiency graphs for that. Then tailor a rear housing to suit your application (street car, drag car, circuit car weekend warrior, daily driver etc...)
good luck.
and you can get them with the proprietary nissan housings (new, not remade like some of these custom ones) for around the 1600 mark
go see pete at autosport, he's stocking garrett stuff now. was looking at a 3071 before my plans changed
Horror stories I've heard. I haven't used one personally but I don't put China rubbish on my car. My motto is always do it once, do it properly. I've seen first hand results of the 3071R and they can't be argued with.
In my opinion the KKR gear isn't exactly shit, more tedious to get installed. I was at Horsepower In A Box one time, when Morrie was installing a KKR onto a car. The supplied banjo flange etc, was wrong, so had to have a custom one made/find a replacement. Build quality may be a tad questionable compared to Garrett, HKS turbos.
Personally, if I find build quality questionable, I find myself thinking "what else can go wrong"
With our cars, there are so many options out there it can get confusing. But also, you have the experience of plenty of others before you to help decide what to do. At the end of the day it's your money, spend it how you wish. If you can stretch the budget to a 3071 I'd do it in a heartbeat
HKS 2530 or Garret 2860. Nice 250rwkw with boost starting under 2,000rpm with full boost by 3,500rpm. What more could you ask for?
f**k yeah... I love the powerband from my 2860 on my 2.5l...
Solid 200awkw with 13psi. 4cyl though... Full boost by <1500 :P
Edited by turbo x-trail
0.86 if you want more top end power but a bit of a lag monster, 0.64 if you want something streetable, which is what you will use 99% of the time. Depends too if you are going a top mount or low mount manifold, if you are buying a decent tuned length/stainless manifold, if you have upgraded cams/cam gears and how they are set .... there are lots of other variables too.
Just talking to the hypergear guy, would I want a .86 or .64 rear housing? 300 differsnce to go .86
I am running on of the Hypergear turbos......been running it solid for over 18 months or more now.....it hasnt given me any grief and i am running the 0.63 rear housing......makes a nice 246 rwkw and for the boost that you want to be running it will handle it no probs....by reading your post you are after a good mid range performance and not really care about the top end power which is perfect for the daily streeter.....
I think the OP got abit confused. The OEM housings is in .63 which is the OP6, the next one up is in .82. I'm confident that the OEM .63 housing can push out around 260rwkws, but if the power goal is higher then it is definitely better to go for the .82 rear. You find it makes power lot easier using less boost, with better torque and lot less heat.
The down side is .63 is more responsive, while .82 is laggier, So if its a every day car its probably worth going for the standard high flow, But if this car serves most of its life on tracks then the .82 is definitely better.
So three things should be put into consideration:
1. In future will I want more then 260rwkws.
2. What is my purpose of building this car.
3. Would I prefer the current driving ability with mid-low power range (ie Very aggressive with 1st, 2nd and low 3rd gear.) or some thing with hug mid-high power range (ie very aggressive on 4500RPM+ 2nd, 3rd and 4th).
I've got few dyno sheets on my thread, Please have a read which will be very helpful to your decision.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
