Have you driven one, I thought you were a rev head? whats the point in having a turbo that makes most of it's power below the rev range you use it in?
Come for a visit and I'll let you have a drive of my car and you can decide if the lag vs power trade off is worth it.
I tuned Lee's car on 98 aswell and it made 270rwkw at 17 psi on willalls mainline, and his turb is a hks 3037 with .68 rear housing, and IMO the r and d that has gone into the rear housing is why they out perform there garret brother!
  • Replies 54
Posted Images
+1 for adrians crazy top end...
oh i would love to do that.....i have driven Abe's car and that has a 0.86 rear housing running 98 fuel.....so pretty much i should be going the same turbo as lee has for the power and application that i want it for.......3037 with a 0.68 rear housing.....so now where can i get one from??? i really need to talk to you adrian before i get a turbo lol
I got a gcg turb with the same number on the core, but gcg tag says gt3071r...they tell me it has a .71 rear and a 3076 core......im a tad confused now...Is this what your running
Hi
the rear is definitely a .73 a/r AVO housing on mine.
see: http://www.avoturboworld.com/content/view/49/26/ and http://www.avoturboworld.com/pdf/gts_exhaust_housing.pdf
I agree this housing holds too much heat. As found out on the last trackday......
The front compressor is a ported/flowed stock nissan 45V4 rb25 housing - bored to the max.
The centre chra core features dual ball bearing, capable of 450-500hp at the engine, is GT3076R
700177-5015 / gt30 chra
compressor wheel inducer size: 57.02mm
compressor wheel trim: 56mm
compressor wheel exducer size: 76mm
turbine wheel inducer size: 60mm
turbine wheel trim: 84mm
turbine wheel exducer size: 54.8mm
see: http://www.forcedinductions.com/Completegarrettlisting.htm
On the topic of turbos ... where can I find a gasket between the exhaust manifold and turbo for my RB25 at short notice?
I've had a leak in my dump pipe gasket for some time, and now want to replace it (that gasket I do have), but I'll need to remove the turbo completely to do it.
:rolleyes:
:rolleyes:
Nissan stock them..
^^ yep Craig from Spare Parts at Main North Nissan keeps them in stock. Otherwise I have a vgc one off my R34 you can have for free (I changed it for the fun of it while I had the thing off one time). And fyi you won't completely have to remove the turbo (which is a giant pain in the ass getting the water line banjo bolts back it - just undo the turbo from the manifold, inlet and exhaust pipes, and you should be able to lean the turbo out off the studs enough to get the old gasket off and the new one on. will save you heaps of time - just watch you don't bend/kink the solid copper lines (if they are still on there). Getting those banjo bolts back in straight is one of the greatest pita jobs I have ever done on a car.
well said.
just realized Ive got a new gasket here too,
if anyone wants to feel the midrange and juicy topend of my stag (passenger seat, soz) pm me - morphett vale.
got to install new lowmount manifold, bend actuator rod a little, redyno for another 5% gain in power, with an increase in response
Unfortunately I have a custom bellmouth dump pipe and its just awkward to get a spanner to it. I've always had to unbolt the cat, and remove the turbo from the exhaust manifold ... then separate the dump pipe from the turbo.
Fortunately, I have braided lines for water and oil, which make the job a little easier. I'm also going to visit my brother this week (Coventry Fasteners) to get some extra long nuts for the dump pipe, to help make the job easier in future.
However, I will try removing the dump pipe with the turbo just hanging off the manifold and lines still in place. I'll play it by ear on the weekend I suppose.
If you're going to Gepps Cross to help out on the Saturday morning Andrew, I'll grab that gasket off you then?
:rolleyes:
Pretty much, use your right foot as the actuator
^^^yep agree with Luke and Steve
mine is set on 23psi high setting all the time, no point in having a low setting, just control ya boost with ya accelartor
plus you dont have to press any buttons
Just for a interesting comparason. This is in hypergear's thread with a ATR43G2 which is a supposely bush bearing 3076 in their .82 bolton turbine housing. Its actually making better power through all rev range then the 3037 (GT3076 in .70 turbine?) with boost drop. might be some thing to look at.
Hi
Cheers for that , definately a 3076 core then, odd its badged 3071
They told me it was 71 rear, guy i bought it off told me .64..front is polished with m12 written it on..Not sure what size but it needed a 10mm spacer plate..only just.
If its good for 250 ill be happy :cool:
Edited by Arthur T3
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
