I've got a rebuilt rb25det with a gcg highflow etc, currently it just has stock injectors/reg new pump and is running 10psi. Tuner said it is ok on the stock injectors and making about 200kw, anymore though and I risk leaning it out due to 100% duty cycle esp in cold weather or if I get a boost spike.
I had a fuel rail with gtr injectors, magnaflow regulator etc in it initially but it had to pass a full roadworthy so I removed them and got it retuned. Anyway its all on the road and I'm itching for more power, will be getting a Z32 afm and putting the rail and injectors back in, but I am unsure what to do about the regulator. I've read everywhere that the stock one is good for up to 300kw and theres no reason to change it, but being as I already have the reg are there any advantages to using it, or is it just going to make it harder for the tuner to tune? Will be putting the turbo up to 14-16psi depending on how it responds.
The other thing is its shiny and pink so it really screams defect me, so if I put it back in I'm going to paint it black along with the ultra shiny fuel rail to keep it looking stock.
Cheers.
:P
Edited by Rolls
keep the stock reg if it works fine. if you somehow max the gtr injectors way short of your power goals (unlikely) then, and only then, should you consider an adjustable reg
So theres actually disadvantages to the aftermarket reg? What are the differences, just the fact that it is adjustable and you can easily bump the pressure up? Or does the fuel pressure rise differently to a stock one, eg exponentially instead of proportionally?
Sounds like theres no good reason to use it so I will most likely adapt the stock one back on and sell it then.
rising rate regs rise exponentially, normal adjustable ones just let you adjust the base pressure. not sure about the magnaflow but most aftermarket regs simply arent as good as the standard one and also a waste of money/illegal if you dont need it.
Thanks that is all I needed to hear, I will adapt the standard one onto my aftermarket rail. Wasn't sure if the stock ones were a proportional rise or exponential, if they are prop then there would be a definite tuning disadvantage with the aftermarket exponential one.
Depends... some regs don't work all that well.
There are a few nasty experiences with Malpassi (as an example) across my mates so ye... where possible i'd personally stick with stock.
+1 to confirm rising rate is important, stock is rising rate.
Can you confirm what motor you are running? You said RB25DET and GTR injectors... Unless its an R34 NEO can you please explain your use of GTR injectors?
Cheers.
Series 2 rb25det rebuilt with forged pistons etc. Has series 1 running gear and some rb20 stuff as it is in an R32 gts-t. Turbo is rb20 but highflowed by gcg so it is basically identical to a 25 highflow hence the need for GTR injectors.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
