Basically been right through the car.
Had a small amount of rust in the front of the chassis.
That was cutout and plated with the whole underneath of the car proofcoated before the car was complied and licensed.
All new suspension with Koni shocks and king springs.
Selby swaybars
Bigger turbo with front mount intercooler and Autronic computer.
Retrimmed interior with WRX seats
Heaps of other things that I've forgotten over the last 2 years :)
  • 4 months later...
WOW, what a difference a tuner makes.
After the new turbo and autronic fitting dramas I was never that happy with the performance of the car.
Something was just not right but the tuner assured me it was as good as it could be.
It was running out of injectors and needed upgrading so that limited the power to 220rwhp.
The power was OK but the delivery was woefull.
Problem was that changing from first to second near the redline resulted in some lag until the revs built up again.
It was not really pleasant to drive that way and made it difficult to use in the tight circuit as per the above youtube video.
So the car has been sitting in my Son in laws workshop since June as I have no space left at home (too many toys).
We changed the injectors and returned the car to the same tuning workshop (the tuner had loked the Autronic so I had to go back (another story))
Anyway the well renowned tuner only worked contract for the workshop and is unreliable. He started working on the tune encountered a problem then dissappeared for weeks at a time.
i asked the workshop to get their new tuner to look at it instead of waiting so he went right through the car and found a number of problems that the other guy had overlooked. First off the turbo actuator was not operating correctly , there was an issue with the timing causing the missfire that the other tuner walked away from. To the new tuners credit he rang Autronic over east and sought some advise and fixed the problem the supposed Autronic expert tuner couldn't.
Anyway the results are amazing. Not only was there a power increase ,when changing into second this beast tries to shred the tyres :O:):D
This car is so torquey now by comparision. Felt like a new car when I drove it back to my Son in Laws workshop.
He will service the car and we'll do a few other jobs over the next 2 weeks until his new house is finished and the DR gets a permenant home at his place. I can then house the DR or GTR at his place so I can get to drive which one I feel like.
So to summarise
Tuner 1 =220rwhp
Tuner 2 =288rwhp :P
The tuner got the car to post 320rwhp but backed it off at my request as he recommends an actuator change to a lower psi rating to control the boost better.
The engine is stock internally
I've fitted a KKR380 turbo and PI-1 intercooler.
http://www.streettuned.com.au/Forced-Induc...S/prod_462.html
http://www.otomoto.com.au/kkr/intercoolers/index.html
plus a Autronic SMC computer and keeping boost to 17psi.
The 288hp is just a number so not sure what you'll get on another dyno.
Main thing for me was going from 220 to 288hp on the same dyno
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
