s13-steve Posted June 20, 2010 Share Posted June 20, 2010 (edited) Hey guys , Im steve, im back into the import scence after 2 years off - ive owned a few imports before and used to drift my old S13 down at waneroo raceway. Below is my new car which i have included specs and pics and am also seeking some advice with a few issues listed below... SII 1996 R33 Skyline GTS25T ~67,000kms Imported in December 2009, - C's Short Shifter - Pedders adjustable camber bushes - Greddy FMIC - Tein Superstreet Coilover suspension - Whiteline heavy duty front and rear swaybars - Apexi cold air induction - 3in Xforce TBE - Apexi Neo AFC - Greddy EBC - Work Emotion Charcol/Bronze 18in with centre caps - New 235/40's - Bosch fuel pump - Alpine DVD head unit - Original Nissan floor mats - Dark Tint - Autowatch alarm 278rwhp I am having a few problems that i'd like to get some advice on 1) Knocking/ clunking/ groaning/ creeking in front right and rear right wheels ( or that general area) when turning into a driveway, or parking up a kerb when i turn i get a strange groaning/ almost clunking from the front drivers side wheel / rear wheel area - what could this be? the coilovers are new so i was thinking some sort of bushes? 2) Doesn't boost smooth sometimes and doesnt feel as powerful as it should when boosting sometimes i get a moment of hesitation and then it boosts or even a slight jerking in 3rd gear one time. it also doesn't pull as hard as you'd think for the power it has it almost feels like its being "held back" especially at high revs il take it in to get serviced and retuned at all star garage this weekend 3) The car seems to have an auto turbo timer? is this a feature built into the apexi NEO or GREDDY EBC? how do i get the engine to turn off straight away if i need to? 4) does anyone know this car? all advice appreciated. Thanks, Steve Edited June 20, 2010 by s13-steve Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/ Share on other sites More sharing options...
snozzle Posted June 20, 2010 Share Posted June 20, 2010 looks like a nice car man, rip out that safc, buy a powerfc and that is problem 2 solved R&R on stock ecu is what your experiencing, search up about it problem 1 will be a process of elimation between your shocks and other suspension components, or even play in your hub/wheel bearing talk to an auto electrician regarding the turbo timer install, it mite be hidden away under the dash, i dont believe either of those devices can act as turbo timers nice car again, looks to be clean, i actually like the wheels, good offsets! Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5303199 Share on other sites More sharing options...
Just_Rb Posted June 20, 2010 Share Posted June 20, 2010 (edited) the autowatch alarms come with turbo timer option inbuilt depending on what model your best bet is to speak to an autowatch installer to explain how to turbo off or adjust the time of it the sound your hearing is most probably your tyre rubbing against the plastic inner guard when weight is transferred to one side under full lock Edited June 20, 2010 by Just_Rb Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5303208 Share on other sites More sharing options...
syfon Posted June 20, 2010 Share Posted June 20, 2010 I'm guessing, due to the offsets of the wheels, that it is simply the tyre/s rubbing on the guards when turning into a driveway etc. BTW, the offsets of those rims can get you a yellow sticker, so be careful. Other than that, nice R33. Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5303216 Share on other sites More sharing options...
Levi_ Posted June 20, 2010 Share Posted June 20, 2010 The uneven power would be down to needing a retune, the AFC Neo is only a piggyback and it can only do so much. Only costs about $150 for a retune on a piggyback like that, so take it down to a workshop and they'll be able to help you out there. Knocking is probably the front arm bushes, there's one on each side (front tension arm I think it is) that is really common to wear, should be able to get a workshop to sort them out. Just have a look under there, it's easy to tell if they're leaking/split/worn. Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5303218 Share on other sites More sharing options...
NISMOGTT Posted June 20, 2010 Share Posted June 20, 2010 I would suggest as stated that your autowatch has the turbo timer built in... if you look at your buttons face on there should be 4 button 2 large at the top then 2 smaller under them... on mine i simply hit the smaller smooth (right) button twice to turn the car off instantly.. Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5303369 Share on other sites More sharing options...
s13-steve Posted June 21, 2010 Author Share Posted June 21, 2010 I would suggest as stated that your autowatch has the turbo timer built in...if you look at your buttons face on there should be 4 button 2 large at the top then 2 smaller under them... on mine i simply hit the smaller smooth (right) button twice to turn the car off instantly.. Thanks so much for all the replies! Im going to book the car in for a retune and service this saturday ( the last owner got the car serviced at Kmart Tyre and Auto last week lol) Hoping Allstar Garage or wherever i take it can also sought out the clunking/ groaning problem. Also NISMOGTT i tried what you said with the alarm and it worked! My other question is legally, if i got a yellow sticker would this car get over the pits fairly easily? Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5303468 Share on other sites More sharing options...
syfon Posted June 21, 2010 Share Posted June 21, 2010 It's difficult to determine if the car would pass pits fairly easily, however I can tell you, it would not pass pits with those rims as they sit wayyy outside the guards, so stockies would be needed for pits. Other than that make sure the car isn't too loud and simple things like not having all this shiny shyte in the engine bay as it just attracts unwanted attention. Sleepers are the best Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5303531 Share on other sites More sharing options...
s13-steve Posted June 21, 2010 Author Share Posted June 21, 2010 (edited) any idea what the car would do down the quarter mile? my old S13 only had 196rwhp but i still mananged to get a 13.8 out of her CA18FTW (S13 clearly lighter then r33 though) Edited June 21, 2010 by s13-steve Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5303848 Share on other sites More sharing options...
Dani Boi Posted June 21, 2010 Share Posted June 21, 2010 Low-mid 13's with a good launch Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5303850 Share on other sites More sharing options...
s13-steve Posted June 21, 2010 Author Share Posted June 21, 2010 Low-mid 13's with a good launch cheers mate, im looking forward to getting it out for a few runs. Only thing that will probably die is the clutch - i think it may be stock as it feels very light (previous owner was an international student and had no idea about the mods) Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5303855 Share on other sites More sharing options...
syfon Posted June 21, 2010 Share Posted June 21, 2010 Yeah, I'd guess mid-to 13's with a good launch. My brothers old 180sx (CA18DET) was making 230rwhp and ran a 13.1sec Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5303941 Share on other sites More sharing options...
s13-steve Posted June 21, 2010 Author Share Posted June 21, 2010 cars booked in for a retune, service and general look over on friday at allstar garage, will post power results Mid 13's would be fantastic will have to wait and see Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5304072 Share on other sites More sharing options...
That_timothy Posted June 21, 2010 Share Posted June 21, 2010 cars booked in for a retune, service and general look over on friday at allstar garage, will post power results Mid 13's would be fantastic will have to wait and see While you're there on friday, tell 'em to hurry up with my car! Sick of walkin' =P Nice looking car though man. Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5304159 Share on other sites More sharing options...
LANDSCRIBBLE Posted June 21, 2010 Share Posted June 21, 2010 hi, nice car man. mine also makes a rubbing noise from the front drivers side wheel. anyone know if it could possibly be the return intercooler pipe? Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5304840 Share on other sites More sharing options...
alpinestars Posted June 21, 2010 Share Posted June 21, 2010 nice buy dude kinda wish i still left my s2 as it was the noises from your wheels are probably hub bearings and the boost hesistating could be from fuel cut or from afm Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5304882 Share on other sites More sharing options...
s13-steve Posted June 21, 2010 Author Share Posted June 21, 2010 nice buy dude kinda wish i still left my s2 as it was the noises from your wheels are probably hub bearings and the boost hesistating could be from fuel cut or from afm andrew from chisholm? - it Steve C from chisholm man, hows things? - cheers for the info il get all star garage to look into it on Friday Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5304896 Share on other sites More sharing options...
Ninja gts25t Posted June 21, 2010 Share Posted June 21, 2010 It's difficult to determine if the car would pass pits fairly easily, however I can tell you, it would not pass pits with those rims as they sit wayyy outside the guards, so stockies would be needed for pits.Other than that make sure the car isn't too loud and simple things like not having all this shiny shyte in the engine bay as it just attracts unwanted attention. Sleepers are the best ^ agreed just got my car over the pits lol. used to have a screamer but they couldnt spot it. just told me that i had a hole in my exaughst so i said no prob ill get that sorted strait away. and also dont have a cat, housings still there but the muffle was punched out. as u can see the pitsisnt that had to get over. but i agree wid syfon that sleepers are def beta Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5305097 Share on other sites More sharing options...
snozzle Posted June 21, 2010 Share Posted June 21, 2010 wow, u are one lucky son of a .........********* hahaha i joke, but serious about the lucky part, damn, how long ago was that? they are very harsh these days.. Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5305099 Share on other sites More sharing options...
alpinestars Posted June 21, 2010 Share Posted June 21, 2010 andrew from chisholm? - it Steve C from chisholm man, hows things? - cheers for the info il get all star garage to look into it on Friday yeh dude its andrew, thought it was you things been pretty cruisy how bout your self Link to comment https://www.sau.com.au/forums/topic/325689-just-bought-an-r33-skyline-gts25t-pics-specs-and-help-needed/#findComment-5305220 Share on other sites More sharing options...
