i wanna get some 235/40/r18s onto a 10inch wide rim. purely cos i have both lying around and dont wanna shell out for new tyres yet. can this be done, and pls reccomend some places that can do the fitting for me as i know most tyre shops dont like stretching stuff
https://www.sau.com.au/forums/topic/325724-tyre-stretch/
  • Replies 80
yes it can. we use a bicycle tube to bridge the gap that a 225 gives on a 10" wheel, so 235 should be easier. any shop that builds drift cars should be able to do it, they'll have someone there who has the technique down pat.
otherwise if you have till saturday give me the wheels I'll take em up to Campbellfield and chuck em on for you on the machine.
https://www.sau.com.au/forums/topic/325724-tyre-stretch/#findComment-5303724
i'll ring around then, but saturday sounds good. i'll come up wit you tho cos tyres need to be swapped from one pair of wheels to another, and the second pair needs their tyres swapped to another pair lol. might not fit 6 rims plus tyres in your ceffy
https://www.sau.com.au/forums/topic/325724-tyre-stretch/#findComment-5303741
No it looks hardcore Charles. Even 225/235 on 9" looks good. Hardcore!
it is hardcore, because im hardcore. i will f**k your shit up mr dude with pecs bigger than my face
And give you no grip lol. Might as well run stockies :)
interesting thought you have there kis, because thats exactly what i currently run, and they are awe, wait for it......SOME
niroj give wheeltech a call. they are in dande. they will do it for ya. they have done 225 on a 9" and 225 on a 9.5" rim for me so 235 on 10" wont be a problem.
see its only the blek fellas in here that actually show me any love. bloody wasteland whores. plus, atm, my car is turning into a hard parker anyways. i'll worry bout a more practical fitment if i ever bother to get to a track
https://www.sau.com.au/forums/topic/325724-tyre-stretch/#findComment-5304118
I daily a 225 on a 9.5"... don't seem to have any issues. although tyre brand and model has a lot to do with it. Something with a flimsy sidewall will be balls. Also depends on how the tyre seats in the rim, which somewhat depends on the design of the rim.
But....
plus if your car isnt really low its going to look ridiculous having mass stretch and fender gap
I agree. Ngaroj unless you slam the crap out of your 33, stretched tyres are just gonna look stupid. And by slam I mean like less than 1cm between fender and rim (not tyre).
https://www.sau.com.au/forums/topic/325724-tyre-stretch/#findComment-5304969
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
