Hey guys,
Just bought an engine and require the following parts for my conversion:
R34 GT-T manual ECU
R34 GT-T manual engine loom
R34 GT-T AFM
Rb25det gearbox (can be from sII r33) in good condition (local only)
Willing to pay for postage for ECU and loom
Located in Westside Melbourne
Cheers, Jason
https://www.sau.com.au/forums/topic/325746-r34-gtt-parts/
hey jason, do you have a set of ignition coils for it??
i have a great condition set, came of a 60k rb25det NEO.. lemme know if you need them. im just clearing the last of my rb25 stuff out.
https://www.sau.com.au/forums/topic/325746-r34-gtt-parts/#findComment-5304338
Hey guys,
R34 GT-T manual ECU
R34 GT-T AFM
Cheers, Jason
Hi Jason
if you get stuck with the parts you looking, give Erwin a sms or a call i think he got most of the parts you looking for.
0410069096.
https://www.sau.com.au/forums/topic/325746-r34-gtt-parts/#findComment-5304992
