Hey guys,
im just curious for those that have travelled to Japan/ Lived there - what is the general japanese opinion on the R33 GTS-t? it's common knowledge that S13/14/15 R32's are very popular for drift, but what do the Japanese think of the R33 Gts-t? do they get used commonly for drifting/dragging applications? or are they more the commodore commuter equavilent...
https://www.sau.com.au/forums/topic/325749-r33-gts-ts-in-japan/
Damn good question. Ill send this Q on to some friends of mine in Japan n see if they can comment.
Id go for saying that they were like the Monaro in Aus. In most peoples eyes damn good, damn popular, commonish but still make people look, and of course there is always the bigger badder GTS that gets the bragging rights- just like the GTR-GTST
unable to get any extensive comment from peeps, only that it isnt used for drift due to its wheel-base n weight, especially when there were so many other cars out there that are better and cheaper for drifting purposes- eg. sr20det line-up
TBH a lot of them think they are an old car, hard to fit in a pay parking bay because they are a bit long compare to other square cars they've got atm. I actually saw more GTRs than GTS-T when I was there last trip. There aren't that many R33 on the road in Japan :P (compare to Australia)
given that there are so many here there prob isnt as many in J land. Also GT-R's are the price of gts-t's almost in japan so why would you buy a gts-t
I was gonna say, for most people these days, R33s are irrelevant - they're old cars, too old to be of interest to the general public, but not old enough to be considered a classic.
Per capita, there are probably more Skylines in Australia than in Japan.
I would have thought at their peak they would have liked them, as for a while nearly every single R33 that appeared at the docks had an HKS pod and some sort of aftermarket exhaust on them.
Just like those AE101 Levins, it was hard to find one that didnt have the TRD or somethig similar bumper on them.
r33 hav a bulk body than the s12 etc thats 1 reason why they dont prefer r33s
I don't see many R33's owned by Japanese in Japan any more. But I will say that foreigners living in Japan seem to absolutely love them. I guess because they are slightly newer than the R32, reasonably priced, and easy to modify.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
