I'm parting out my GTST, most parts have only recently been installed and are basically new. I just don't have the time and patience for the car anymore so its all gotta go.
The long motor was purchased stock from a local import wrecker and has good compression on all cylinders, no leaks and ran well 2 weeks ago when i started it but i've got no idea how many k's are on it im guessing just over 100,000 since the timing belt i replaced looked fairly new. Cams, headgasket, timing gear was all done recently the bottom end hasnt been touched but the bores and pistons looked schmick when i had the head off.
GT35R .82 rear housing, 6Boost Manfold with black ceramic coating, Synapse 40mm Syncronic Wastegate, Water/Oil lines and HKS Bellmouth (no dump or cooler piping, only test run on the motor for 10mins tops) - $3000
RB25 Long motor with tomei pon-cams, acl race series mls head gasket, gates racing timing belt and new tensioner, greddy knock off plenum and VH45 Throttle Body (will include top feed injector setup with 650cc siemens deka injectors and aeromotive a1000 fpr for an extra $500, no ac or ps pump) - $2500
RB25 Complete Manual conversion (has exedy heavy duty clutch thats fairly worn although it didn't slip with the old motor at ~350rwhp) - $1250
BC BR Coilovers, HI-CAS Lock bar and Rear camber adjustment bars (only just been installed in the car haven't driven the car with them yet) - $1400
Haltech Platinum pro r32/r33 plugin ecu with extension harness, couple of marks on case but barely used - $1700
Clear side repeaters - $20
18" 350Z Touring V2 Rims, small marks on 3 rims and decent gutter rash on 1, 1 new tyre and the rest would have over 75% tread. - $500
Bosch 044 and 2.5L surge tank - $200
600x300x100 Intercooler, 3" inlet and outlet - $70
ASI 50mm Alloy rad and twin 12" Thermos - $250
VH45 Throttle Body - $100
Pics:
Everything is currently still on the car (if anyone is interested in the whole car lemme know) so if you want pics of certain things ask. The whole car is being parted (except the nitrous gear atm) so if you need something just ask everything has gotta go and i wanna get rid of it all asap so feel free to make sensible offers. Will separate items if i have buyers for everything.
Will add more later this week and get more pics.
Edited by slo_sprint
https://www.sau.com.au/forums/topic/325760-qld-parting-out-black-s15-r33-gts-t/
Pics:
interested in the 6boost manifold
fuel pump and surge tank
front facing plenum with throttle body
injectors and fpr
intercooler
pm me with best price for the lot
injectors and fpr
intercooler
Can't PM yet man, just so ya know the manifold has a Tial 2 bolt wastegate flange.
Can do it for $2200 but id like to sell the manifold with the turbo gear together or at least have buyers for all the stuff so i'll let ya know.
Anychance posting to 5173 Adelaide for $30
cheers
Can do
how old are the coilovers any leaks or knocks and spring rates etc?
cheers
Basically brand new, installed them and thats it so no knocks or leaks. Pretty sure the spring rates are 8kg front and 6kg rear.
Fuel pump and surge tank sold!
Better pics of engine in this gallery http://yfrog.com/0aimg0885hjx
pics of throttle body? will you send to wa?
Pics in the link above, will send to w.a. no dramas if you pay postage.
350Z Touring V2 Rims got pics of "decent gutter rash " one? how much to get it to melb?
Pics of all wheels in the link, no idea how much itll cost it'd be too heavy for aus post so i'll leave it up to you to organise shipping.
Hi mate,
How much for the greddy plenum and 6boost manifold?
Thanks,
Pete
I'd looking for around $1200 for the manifold and ill take $200 for the plenum but im not willing to separate them yet.
Where abouts are you located? Im interested in the gearbox conversion and radiator?
I'm in Sheldon in QLD man.
One VH45 Throttle body and clear repeaters sold.
C'mon people im wrecking a whole car here, panels, interior, lights, sunroof, suspension everything is up for grabs i need space for the new car.
Engine, turbo kit, ecu and manual conversion listed on ebay and will add more during the week
hey man how much do you want for your front bar and front left lower control arm? and do you still have the intercooler?
Front bar you can have for $30 but its in need of paint pretty bad the lca i dunno like $20?
im keen on the conversion kit.how much to post to melb? how many k's has it done? gimme ur number n i'll give u a buzz. cheers
PM Sent
Long motor with plenum and vh45 tb, turbo gear, intercooler, wheels, fpr injectors and rail all sold
    • Thanks! Will get it looked at before winter 🥶 other than that she's a mint ride love it aye
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
