My clutch is on its way out and i need a new one in the next couple of months so im wondering what you guys suggest. Im not going to be pushing anymore than 200kw at all 4's so i dont need anything real great.
Need a reasonable priced clutch with exact part numbers and the ruff price if anyone can help
Thanks
Stu
https://www.sau.com.au/forums/topic/325766-rs4-s-clutch/
Probably not the best advice, but when I imported my 260RS it came with a horrible HKS triple plate clutch, that I absolutely hated. Mates called me a wuss and said I can't handle a real mans clutch. Until they ALL stalled it over and over. If stalling is your idea of a good time, then yeah, great clutch.
I got rid of the HKS and got a single plate Nismo Coppermix clutch. This clutch is the boomshanka of clutches. I can come to almost a complete standstill in 2nd and it don't stall. City traffic? Not a problem. Its light, its easy and behaves like a standard clutch. I'm pushing 300 killer wasps in my car, and the Nismo Coppermix doesn't miss a beat. A wee bit pricey (I picked up mine online for cheap) but either way, worth every dollar. Do some research on them, I'm sure others can vouch for their goodness. A really great all rounder.
https://www.sau.com.au/forums/topic/325766-rs4-s-clutch/#findComment-5304347
I'm thinking of going for a Nismo Coppermix single as well - my clutch doesn't slip, but I'm sick of the constant shakes and on/off nature of a button clutch being used in a daily-driven car. Hopefully it'll be lighter to use, too.
https://www.sau.com.au/forums/topic/325766-rs4-s-clutch/#findComment-5305009
you should speak to jim berry, i've heard that he is really enthusiastic but realistic
you tell him what you do with your car and what you are planning to do with it and he will come up with the best compromise
i've heard he also does a custom clutch using rb26 bits and pieces and you get a higher clamp load with stock ish plate that will hold good power and feels like stock
let me know how much yours ends up being, i think im in the same boat as you :P
https://www.sau.com.au/forums/topic/325766-rs4-s-clutch/#findComment-5305034
I'm running a Nismo lightened flywheel, Nismo 1200kg pressure plate, and Nismo Coppermix clutch plate. Cost me $300 used and then another $200 or so for ACS to machine the flywheel and pressure plate and check it all over. Its great to use, even as a daily. I've never stalled the Stagea with it. And its holding 204awkw without any problems.
:rolleyes:
https://www.sau.com.au/forums/topic/325766-rs4-s-clutch/#findComment-5305257
not to hijack this thread, but im looking for a clutch kit for my s2, and as our cars have r33 gtr running gear, just wanting to know if a r33 gtst push type clutch kit and flywheel will fit. or does it need to be a gtr kit?
https://www.sau.com.au/forums/topic/325766-rs4-s-clutch/#findComment-5305333
r33 gtr or r34 gtt clutches (also late model r32 gtr's too)
they are a pull type
https://www.sau.com.au/forums/topic/325766-rs4-s-clutch/#findComment-5305345
Gday hows things?
How are you going with the clutch, have you got any prices yet and if so how much roughley as mine is on the way out so i need to start saving :(
Also I am pretty sure we have found a way of locking up the hicas without removing the rack, very easy job. I will post up pics and explain more when done should be with in the month
cheers
https://www.sau.com.au/forums/topic/325766-rs4-s-clutch/#findComment-5314789
to lock your hicas just put a washer on either end of the rack . need about 2 mm either side
BNT in chch nz quoted me 380+ for standard clutch and 660+ for heavy duty coushined button for my rs four s
for Xtreme brand
https://www.sau.com.au/forums/topic/325766-rs4-s-clutch/#findComment-5314825
Gday hows things?
How are you going with the clutch, have you got any prices yet and if so how much roughley as mine is on the way out so i need to start saving :blush:
cheers
Yeah im good mate how are you, havent sourced anything clutch wise yet will let you know when i do! could last a couple of months yet. I dont wnat to replace it until it shits itself.
I thought u had a auto stagea?
Dont have to worry about the hicas, My reasearch in finding a lock bar came to a pretty abrupt end. Found a cusco one but they said its only for race purposes. Im going to rebuild my hicas as i know this dude at nissan dandenong and he can get all the parts to do so and its not that dear.
Stu
https://www.sau.com.au/forums/topic/325766-rs4-s-clutch/#findComment-5315295
