Black R32 Gtr For Sale
G'day all up for sale is my Black R32 GTR specs as follows
North Nowra but i work in wollongong during the week
Interior:
Momo Steering wheel
turbo timer
Nismo Gear shift knob
Pioneer headunit does mp3 and can connect to ipod/iphone with special cable
Interior is in excellent shape no major stains, no tears or rips, the only part that looks worn is the gearshaft boot. All standard trim
Exterior:
All stock body panels and such
Paint in excellent condition for a nearly 20 year old car, no major chips or scratches
Suspension and wheels:
standard rims with good tread on the tire
Aftermarket adjustable coil-overs
Drivetrain:
Has Aftermarket front driveshaft unsure of what brand but was recommended by gibson motorsport
Engine:
Genuine 143XXX on the clock
my oil pump got clogged and wasn't pumping enough oil to the head which was damaged. Mechanic took apart the engine (when fitting new oil pump) and said pistons where not damaged.
Have since replaced with a different reconditioned head with reco camshafts springs valves etc
Brand new Nismo N1 oil pump with JJR collar
New engine mounts
Brand new 40mm radiator
Front and rear strut bracings
New head gasket
3inch stainless steel exhaust and massive cannon
HKS pods
ARC bov
Just had a full service done
Selling the car as i have a family now and want something a tiny bit more practical
Its defiantly the best car Ive ever driven and i will probably cry when i sell it, a very regretful sale
Asking price $18000 ono
Contact is 0408423222 or send me a pm
Cheers Mick
  • 3 weeks later...
 Share
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
    • Ok so I have a little bit of an issue. So I have a 1992 r32gtst and trying to replace the rear wheel bearing and spindle the research I’ve done shows a different style bearing than what is currently on my car. So the picture of the new bearing with the box says it’s the correct bearing as does my research but the picture shown of the old bearing is the one that came off the car. I’m a bit confused the new bearing has an ear on it that I’m assuming goes to where the top of the ebrake shoes mount as to where my old bearing does not. Any help would be awesome
    • What in the absolute mind f**k. Generally speaking, you cannot diesel a petrol engine without sparkplugs which you don't have since you're disconnecting battery.... Something is very fishy here.
