Lakeside Classic Speed Fest: Winfield R32, Jim Richards And Mark Gibbs
I just searched the brisbane council website and they reckon they'll be doing demo laps and racing
http://www.ourbrisbane.com/whats-on/events...ssic-speed-fest
i reckon i'll ask the people on the gate if the skylines are running before i pay, was a little disappointed last time, although still good to see some great cars running around
Yeh sorry about last year.....don't think Terry was planning on doing an exit into the walls. Was my fault on the R31......the cam cracked on a cool down lap which as you can expect pretty much stuffed the top part of the engine.
What I can confirm at the moment is that there is definitely 2 R32's running, The R31 blew a head gasket at Morgan Park and more than likely wont be running and the DR30 is definitely running(might even have some HP for this event....going on the Dyno today).
The rest of the Group A/C field looks pretty good as well.
C'mon, a headgasket isn't hard to replace. Hell, bring the car and the R31 club boys will fix it with duct tape and cable ties in the paddock :)
At least tell me the car will be there on display if its not going to race?
Sorry wont be there at all unless his changed his mind from when I spoke to him on Sunday....the head Gasket was only the start of the damage....also detonation in 5 and 6.......the new owner does have a spare motor but his had a fair bit on his plate in the last month or so so I am pretty sure he wont make it back to Sydney - Motor out - Motor in - Dyno - and back to Brisbane by next weekend to race it....logistic's alone would have him pretty buggered.....I have offered to help him even though I am still working on the DR30's prep but I am pretty sure he wants a break before Muscle Car.
Edited by Jetwreck
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
