I hit a big hole on the Old Pt. Wakefield road near Virginia a few years ago in my XR8. Went to the Playford Council and the guy there said get a quote for the two rims, which i got from Ford at app. $600.00 each. I took the quote and the wheels to the guy and he authorised a check for me with which I went out and bought 4 second hand rims with tyres. That section between Virginia and Pt. weakefield road has actually been repaired, but there are plenty more rim busters around that way. The thing is they don't just bend rims, they destroy all the suspension and how can you put in a claim for waht is accelerated wear and tear. A friend also tore off her exhaust on an exposed steel water works cover in the Virginia Post Office car park and the Playford council coughed up for the repair bill. But many years later there has been no maintainance and the steel covers are way above ground level again. This car park is 4WD territory. The council has very recently done some very large patch work sections on Heaslip road near the Gawler River but they have left as many pot holes as they repaired, and when they do patch the individual holes the fill just vibrates out in a very short period, especially when it's wet. Even if you don't bend a rim you can easily knock out the wheel alignment which is another expense and time waster, which my wife and I have done on more than one occasion. Also you don't always swerve in time to miss them let alone if there is an approaching vehicle and/or the occasional pushbike in the way. I don't want to hit one of these holes with my BBS rims at 100kph. at 2k plus per rim I won't be a happy chappy.
well times must have changed since then ive fought them twice now for no win good luck if you bend rim in the future in the playford area
  • Replies 40
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
