hey guys,
its all finally coming along with my suspension needs. having just sourced some drag radials and in the midst of combining a soft shock/spring combo and then finally ordering a 1.5LSD, ive started to think about what i can do to make sure drive shaft components stay together, or at least try to :rolleyes:
Don't know much about it but i was wondering;
How does the gearbox, tail shaft and other important components hold up with a 500hp rwd vehicle? what are the common weak links in a r34 gtt. and what should i be focusing on?
the car currently has a Nismo Coppermix Twin Plate which is mroe then enough for the 500hp.
p.s: the car is staying MT
any help much appreciated.
https://www.sau.com.au/forums/topic/325847-driveshaft-upgrades/
Two of these puppies for starters.
Diff and tailshaft don't usually have trouble. You have, are going to upgrade the diff center anyway.
Not sure if the 6 bolt flange on the GTR shafts will bolt up to the GT-T halfshafts that slip into the diff though.
thanks for advise sean,
apologies for the dumb questions but what exactly is that? is that the center diff? how much do these fetch for? and where can they be sourced?
dont aftermarket companies make these sorts of stuff?
how do the Rb25 gearboxes hold up?
Edited by Jap_Muscle
I know that some people put in a whole GTR rear cradle that has all the diff, shafts etc already there, Abo Bob is one member that has done the GTR upgrade, so he would be more helpfull with the details.
The 25 box is basically the same as a late R33GTR gear box so they are pretty strong, especially for RWD. Only weaknesses are third gear and synchros at high rev fast shifts.
Os giken and Par etc are a couple of gearset upgrades available.
http://www.skylinesaustralia.com/forums/R3...html&hl=gtr
http://www.skylinesaustralia.com/forums/Gt...html&hl=gtr
http://www.skylinesaustralia.com/forums/Di...html&hl=gtr
Buy complete r32/33 GTR rear cradle.
Use the axles, hubs and diff out of it .
Throw the rest in the bin.
If you want a 1.5 way you will have to get that done at same time.
Fairly easy exercise. Wont need to worrie about breaking axles again.
I have just done the conversion into my R34 GTT
This is the right answer.
I paid $700 from a mate for the the lot from an R32 GTR. My traction control stopped working, and presumably the ABS, although the rear isn't really a problem in most ABS needing situations.
I did it because I snapped a drive shaft.
you would probably wanna upgrade sway bar and traction brackets etc... rb25 box's are probably the strongest outta skyline boxes.... tail shaft will be fine... ur diff on the other hand might not last too long... if your serious and have the $ to back ya idd go borg warner 28 spline or 31 spline diff outta vl or r31... they run 9's in em just fine so you'd think they'd be good but you needa modify/change the brackets etc...
can the billet gtr driveshafts that hi octane fit into the rear without having to mod everything? from what ive seen they come as just the splined shafts
sorry just following up on this
if i put a gtr rear cradle in my car with a gtr 1.5 way diff can i use the hi octane billet drive shaft set
im in the same position as the op just with a shit load more power.
and ill be using the 25 box with os gearset inside it.
  • 4 weeks later...
^ be good to know that as wel. those babies look tough as.
i had a chat to SydneyKid (gary) not long ago and i remember him sayign that the R34 GTT already had GTR hubs and axles when Nissan built them?
i might have misheard but i do remember him saying the GTTs had similar drive train components to the GTRs. can anyone confirm what?
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
