Hey
How much am I worth?
A little about me.....
I was born in 1997, 1st of my series, as a Nissan Stagea RS V Four Station Wagon, RB25DET engine, Attessa all wheel drive, automatic
Looking beautiful in my Silky Snow Pearl paint and Dayz bodykit, with twin sunroofs I was sent off to The Land Downunder in 2003 with 48000kms of use.
My new foreign owner drove me for 25000kms in 9months then sold me to my current owner, I call him bigfoot but sshhhh dont tell him that, way back in June 2005
5yrs and 35000kms later Im still feeling great! He's done a lot of work to me, and one day I hope for my rb30 bottom end lung transplant upgrade under the xmas tree!
Sigh how i wish, never mind.
With the following beautiful modifications, what do you think Im worth to someone who'd love me?
Engine:
Ryco Z201 fuel filter, Ryco Z145 oil filter, Royal Purple 0w-40 full synthetic engine oil
Bosch 040 fuel pump with direct battery feed at 13.8volts
Splitfire coil packs
NGK BCPRE6 0.8mm copper v-groove spark plugs
Davies Craig automatic transmission oil cooler upgrade kit
MV Automatic manual electronic shift kit & auto service kit
Koyo Radiator upgrade
Greddy remote oil filter relocation kit
Fujimoto sump plug drain valve
Catch can kit
Nismo adjustable fuel pressure regulator
Nismo Z32 Air Flow Meter
3inch JustJap stainless steel single dump pipe system
3inch high-flow metal race cat
3inch cat-back exhaust system with Magnaflow mid-muffler and Kakimoto GTR Racing rear-muffler
Cold Air Radiator air guide for cold air induction
Apexi power intake pod filter, using standard snorkel air feed & under body feed
Trust 600x400mm FMIC bar & plate, with custom hard pipe kit
Hard pipe turbo intake kit
HKS heavy duty turbo actuator
Garrett GT3076 700177-5015 IWBB Turbocharger with ported Nissan 45V4 front / AVO .73 rear housings
60mm diameter 84-trim GT30 turbine and 76mm diameter 7/14 bladed compressor wheel
JDM S15 Silvia 450/480cc injectors
ARP head stud kit
Ported, Flowed & Machined headwork including new valve seals, valve seats and valve guides
EPP Clear camgear timing cover
Cometic gasket kit including rocker cover, intake manifold, intake collector & exhaust gaskets
Cometic head gasket 87mm x1.2mm
Aerospeed adjustable exhaust cam gear pulley wheel
Tomei 256 intake / 256 exhaust poncam camshaft set
Tomei 8.8mm high lift springs
Tomei oil gallery restrictor
700177-5015 GT30R chra specifications:
compressor wheel inducer size: 57.02mm
compressor wheel trim: 56mm
compressor wheel exducer size: 76mm
turbine wheel inducer size: 60mm
turbine wheel trim: 84mm
turbine wheel exducer size: 54.8mm
Suspension:
Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
Whiteline front and rear heavy-duty adjustable sway bars
Dayz adjustable engine swaybar, custom Spatz adjustable boot sway bar
Whiteline front castor kit
Whiteline rear subframe pineapple alignment kit
Uwe Jean Ballou R32-GTR 17x9.5 inch rims
Marshal Mactrac TX tyres, 235/45/17
Brakes:
Maltech stainless steel braided brake lines, front and rear
DBA 4000 slotted front brake discs
R32 GTR Sumitomo front brake calipers
Cusco brake master cylinder clamp
Bendix db1144 rear brake pads
QFM A1RM track front brake pads
Audio:
Clarion stereo tape unit with 6-stack cd player
Clarion amp mounted to enclosure for Clarion 10inch subwoofer
Pioneer 260w 4-way front door speakers
Eclipse 80w 2-way rear door speakers
MP3 USB player - radio tune, cigarette lighter adapter
Razin volt stabiliser kit & car alarm
Interior:
SAAS D1 Drift adjustable race seat
Flynn racing low mount R33 seat rail
Apexi electronic boost gauge
AEM F/IC-8 Piggyback ECU with Dell c640 latitude laptop
Greddy Profec-B spec-ii dual stage Electronic Boost Controller, set to 1.00 bar and 1.20 bar
Toshi ecu remap
Boostworx tuned 249rwkw
Parts Not Yet Fitted:
AEM wideband kit
Air flow metre
Oil pressure metre
Oil temperature metre
Exhaust temperature metre
30-row oil cooler
Low mount stainless steel heat-wrapped exhaust manifold
:angry:
signing off, Saidy, the Cleaning Lady :P
https://www.sau.com.au/forums/topic/325858-what-am-i-worth/
biggest problem at the moment is a dead market.. cars just aren't moving. fantastic if you are a buyer because you have the upper hand but terrible if you are a seller.
unfortunately you are not going to see much of your hard earned returned, as i'm sure you are aware.
it all comes down to finding the right buyer at the right time (something is only worth what someone is willing to pay) but my guesstimate would be around the 14-15k mark
Edited by M I K E
https://www.sau.com.au/forums/topic/325858-what-am-i-worth/#findComment-5305849
I wouldnt mind a Series-2 auto
Id flog off the complete Neo engine, brakes & ecu, and drop in my track car parts:
ie:
rear R32 GTR brake calipers, new Slotted DBA 4000 discs, QFM A1RM track pads, braided lines
new front Wilwood Racing 4-pot brake calipers, Drilled 324mm brembo rotors, Wilwood pads, braided lines
new 235/45/17 KU36 tyres
In goes the R32 GTR RB26dett engine, with z32 afms, GTR fmic, new YellowJacket coilpacks, new Siemens 550cc injectors,
near new highflow turbos, new hardpipe kit, new OBX headers, hks split dumps, OBX new turboback "greddy mx" type exhaust,
new 52mm radiator, fuel pump/lines/swirlpot, various guages and parts to suit from the r32 sedan donor car.
Id install shift paddles, and spend a few grand at mv autos (blackwood, sa) on shift kit, auto rebuild strengthen-up, etc.
The rb26 engine would be rebuilt with 87mm hks pistons and a whole heap of crazy gear I already have.
I dont see why I couldnt sell the S1, buy S2, sell s2 parts, install track car parts, sell remainder, and not really pay anything.............
:P
Or do as I planned, install manual shift kit system to my s1 auto box, plus the rb26 stuf above.
yeh. fark it.
who wants to help me remove an engine or two ? :angry:
Or buy a S2 anyway and have both !!! Rb26 into S2 as above, dirty RB 30 bottom end to the S1
woooot
LOLz
https://www.sau.com.au/forums/topic/325858-what-am-i-worth/#findComment-5305859
Haha brendo,nice ad man
it's hard to say wat she's worth,I tried to sell mine until I realised that if someone did coming with the cash and pay the full asking price,I still wouldn't be happy to let her go
guess you need to work out wat kind of cash you would be happy with to hand the keys over
i know it would break my heart to see someone else drive my stag past me( I still crack the Sads wen I see my old black s2 rx7 that I sold 6years ago!!)
decide on a price,stick to it.if someone isn't happy to buy it for said price,keep it and transplant that rb26 you have into it...
Peace out dude
https://www.sau.com.au/forums/topic/325858-what-am-i-worth/#findComment-5305860
That was all the car ^
silly miss
I'll sell her engine as a head, turbo & bottom end (she'll hate that) and get say 4k
ecu, other stuff another grand. Put that into rb26 build
drop in said rb26 and do skids out of the change
https://www.sau.com.au/forums/topic/325858-what-am-i-worth/#findComment-5305881
I got told a stock s2 was worth about 17k when i took out my insurance about 3 months ago, however like you guys are saying there are heaps of stags on the market atm and no one is buying them, the one i bought started out at 16500 and ended up going down to 13500 before i bought it, regardless of all the mods I would agree with mike that you would probably only get like 15k max
https://www.sau.com.au/forums/topic/325858-what-am-i-worth/#findComment-5306209
Not clear why you want to sell it. In NZ a stock S1 RS4T is worth about $5k. My S1 after spending about $15 - 20K on it would sell for about $8k so there's no way I am ever going to sell it!
All your car needs is an RB30 bottom end and a manual box or a hugely beefed up auto (oh and possibly a GTR rear end)!
https://www.sau.com.au/forums/topic/325858-what-am-i-worth/#findComment-5306354
musta been stoned,
decided to take out the rb26dett from the r32 sedan, plus the intake/fmic, bov system, powerfc, new 4-pot wilwood calipers, pads, brackets, lines & 330mm rotors,
I'll grab the rear calipers from the sedan and swap with the stagea rears, and keep the new ku36 tyres
then I'll sell the r32 4-door sedan stripped shell with:
stagea rear & r32 GTR front calipers/slotted rotors/braided lines/pads, spare front Stagea calipers/lines/pads
17x8" Stitch mags/new tyres,
front/rear Greddy strut bars,
front Bride seat rails/ Bride drivers bucket seat, Gehpardo seat
stock rear seats, seat belts, GTR fuel pump fitted, GTR rear wing, spare gtst rear wing with led brake light
Cusco roll cage, spare 4wd roll cage
tomei 320kmph dash, replacement speedo cable/bonnet latch cable
5spd manual rwd gearbox/clutch in excellent condition,
new steering wheel/adapter/gearshifter/boost gauge,
koyo radiator and trust intercooler with tein adjustable suspension
it will just need an engine. complied, rego'd for rb20. no engine/ecu. 4g firm.
I'll then sell my gt3076r turbo, dump/front pipe, manifold for near 2g, sell the ported Tomei head for 2g and sell the bottom end & ecu(s) for another 1g
sink 2g into the auto and around 3g into building/tuning the rb26 with all the insane parts I have collected off ebay - means all up it'd cost me 10k to do changeover once all costs considered.
(ie new forged rb26dett built/installed/tuned + new strengthened auto)
everything is ready to go, as listed above all costs already paid for and/or covered via sales, so Im going to do it.
stuff the rb26dett has waiting for it:
Greddy oil filter, Ryco fuel filter, Champion Gold sparkplugs
550cc Siemen Denso Injectors with new O-rings & seals
Yellow Jacket coil packs
ASI 52mm dual core alloy radiator
JC-Project radiator silicone pipes
1L alloy radiator overflow can
Fujimoto oil drain valve
Z32 air flow meter kit
600x400x100mm FMIC kit
Walbro 305LPH external fuel pump
4 litre alloy fuel surge tank with 5m braided fuel lines & speedflow fittings
Fuel pressure regulator kit
1L Oil catch tank with mini-airpod filter breather
Oil filter relocation kit with speeflow fittings
30-row oil cooler unit
Wilwood 570 High-Temp racing brake fluid
324mm drilled Brembo disc rotors
Wilwood Racing Superlite 4-piston forged calipers & pads
Braided front brake lines
GTR rear 2-piston caliper & QFM A1RM 780degree brake pads
17 x 7.5inch RJR Grafic mags
235/45/17 Khumo KU36 semi-slick tyres
rebuilt turbo's
AEM wideband sensor gauge
OBX tuned-length manifold
Twin HKS split dump pipes
OBX flex split front pipe 2x 3.5" into 3"
Decat flex pipe
Apexi Multichecker
Apexi R32 GTR Power-fc
Greddy clear cam cover
Tomei oil gallery orifice
ACL Race main & conrod bearings
HKS 87mm pistons
Attkd H-beam conrods
ATI 600hp Harmonic balancer damper & pulley kit
HKS step-2 valve springs
Greddy N1 Street Special camshafts
Precision adjustable intake & exhaust cam gears
N1 water pump
HKS oil pump
ARP Head stud kit
ARP Main stud kit
Tomei oil baffle sump plate kit
Cometic Street Pro 87mm head gasket
Cometic SP MLS full Rb26 gasket set
Greddy timing belt, drive key, tensioner & idler bearing kit
plus some other stuff, ie bolts etc
https://www.sau.com.au/forums/topic/325858-what-am-i-worth/#findComment-5310072
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
