like someone said on this forum a while back; if all you can fault with a r33 is its cosmetics, which are very subjective, then you really need to rethink your argument that the car as a whole is "shit"
Precisely, Even if i preferred the look of the 32 over the 33 I would take a 33 just on its engineering and mechanical superiority.
  • Replies 85
Funnily enough CPD when i first joined the forum I had no hate for any of them It just got very old very quickly having the flat cap brigade rag on the whale for no reason other than they didnt like the shape. Well if thats their only argument they can go blow goats. The 33 kicks 32 arse by design Thanks to nissan.
Even as a heavier car it owns the 32. They appear to have difficulty dealing with it.
Farken bring it I say flatcappers. :D
Wasn't meaning you dude :P Just in general. I love my 33 to bits... I much prefer it to the 32 GTS-T. You can't compare a GT-R's styling to a GTS-T (or GTT, same diff), so it's not part of my argument.
edit::
oops just realised you were agreeing
I see lots of 32 gtrs with the rear spoiler in place ther eis nothing wrong with it
It not a towel rail like the r33
I guess the 33 is later model and so its better engineering I agree with that
If you are using your magna / r33 for daily transport then i guess that matters. but really if i wanted a two door magna then i would just put the kiddi lock on so the back doors didnt open
The r32 was built to be a race car the r33 was a magna with out the extra doors so people could pretend to be a race car and still drop the videos off on sunday
As an additional reason why the R33 isn't favoured in Japan is because it doesn't follow the typical Skyline shape that goes right back to the C210. It's that "sleakish, angular" look (lol might have to use your imagination with that) was present even on the R32 and R34, but in comparison the R33 was the odd one out. Example: R30, R31, R32 - evolutionary design, less angular with the R32. R33 - round 90s jelly look. R34 - Back to the angular look but updated for the 2000s.
Those descriptions are pretty lame I know but that's the essence of the styling in the Japanese context so I've been told by some Skyline owners. The R33 is the odd one out and reflected that in the huge amounts that were exported to the point that you're more likely to see an R32 than an R33 getting around. Also too at the time I think Toyota gave some stiff opposition to the R33 sedan with the JZX90 sedans of that era which are still fairly easy to come by in comparison, mainly due to the local Japanese still wanting them!
I like the R33 by the way, I had a GTS coupe (yes NA 2.5L boo) but it was a good decent daily and it did skids.
I see lots of them with them off too just as I see lots of 33's with them left on. Not so bad tho because they're not an ironing board like the 32.
You have no choice, Eat it!
I guess you do use your flat cap as a daily and thats why it burns your arse that the 33 is the above.
The 32 was built for all the same intents and purposes and variants as the 33. 2 door, 4 door family hack etc etc.
You got nuthin bish. suck it up and buy a whale.
Clealy a disgruntled magna owner,
Im sorry you bought the wrong car
I love 33's and S14's (which is exactly the ones the baron pointed out are like the black sheep in Japan... weird).
I love 32 GTRs and any turbo 33 or 34. The only skyline I don't like is the 32 GTS-t and that's because of the RB20.
I love the R33 body because it pairs nice, clean styled lines with one hell of a motor! 32s and 34s just look angry all the time, there's no finese to them.
I don't think anyone's arguing with that fact LOL.
Yeah you see the odd R33 GT-R in Japan, but the GTS-Ts have all been sent over to places like here for bogans to put 20x7.5 chrome rims on, and 18psi through the stock turbo :yes:
Given the lack of aftermarket support for them over there, I think that really says it all.
Also RB20 haters need to get a life, the RB20 is an inherently stronger motor than the RB25, and for most applications they can be made to perform equally well!
BULLSHIT!
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
