hey all, this is more a "just curious" topic, but i purchased a car (havnt picked it up yet) and the car has a 3.5 inch zorst with a stock turbo, now in the past ive had a 3 inch zorst on the same system and found it enough, but will 3.5 inch be worse for the performance of the car? to me it seems like there wouldnt be enough back pressure.
Anyway, i guess the MAIN question is, how much of a drop in perfomance will there be with this exhaust? should i invest in a 3inch?
stock PSI to BTW
cheers
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/
It will not hinder performance.
EPA issues however are most likely.
sound or pollution?
An exhaust CAN'T be 'to big' UNLESS you are going to give the exhaust 'to Big Al, your mate'.
Otherwise it is 'too big'.
But in this case, it isn't.
:P
i dont get it
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306028
sound or pollution?
i dont get it
Lol. 'to' and 'too' - two (hehe) different words.
The problem will be with volume, but I wouldn't worry about it (unless you get defected).
The size shouldn't make any difference to emissions as long as there is still a cat.
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306048
no i don want to take the cat out, srsly, i dont want the extra 500rwkw from taking the cat out, its just to fast for me, so ill leave it in.
i was under the impression that you need some sort of back pressure, but iono
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306058
I believe the extra 500rwkw will make it too fast for you.
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306088
turbo engines are rather different to natro engines when it comes to exhaust requirements. as has been said, you won't notice any difference between a 3" and 3.5" system. if it was on a NA car, then it would be a totally different story
ok, good thanks! :P
i dont realy care about the size, i just didnt want it to be any worse than a 3 inch, which i beleive is optimal for a stock turbo.
is that all you picked up? lol what about - don, srsly or iono, but its good to see u picked up a missing "o"
cheers mate :angry:
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306102
As far as I'm concerned any of those 'made up' internet slang words mean you are speaking another language.
But mix up your 'to, too, two' or 'you're, your' etc while attempting English and it's just plain slack. :P
But srsly, your exhaust is fine.
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306173
hehe ok cheers mate
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306181
It won't decrease performance, on engines with forced induction the less exhaust restriction the better.
My 33 had a 3.5" system with a stock turbo and very few mods and it was pretty damn loud (didn't have a cat or any mufflers bar the cannon though), did sound mint but.
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5306751
Provided you have control of the fueling and timing it shouldn't be a problem , noise and cops aside .
The theory is that the best exhaust is no exhaust behind a turbocharger which obviously isn't going to cut it in a road car .
The turbo rally people like to start out big behind the turbo and step down in stages on the way to the back . What this is said to do is maintain gas speed in the exhaust system as the gas cools and contracts so to speak .
Its a way of having a large volume behind the systems chief restriction , all gasses are channelled and accelerated into the turbine housing , so the red hot gasses have room to expand into . The way to drive the turbine is to have hot gas at speed on one side and a large volume to spread out into on the other side .
As the gas cools it wants to slow down if the exhaust tract is the same all the way to the back , if it slows down too much you can have reversion issues if say the turbo/exhaust manifold/ports/valves/cams are sized to make high rev grunt .
So , the way to keep it moving is to step the tube size down in stages so that the gasses maintain some momentum and velocity .
My old dinosaur Subaru RX Turbo (1.8L 2 valve tiny port flat four GT2554R turbo) has a 3" tube from the turbo to the back of the gearbox and 2 1/2 from there . Its surprisingly quiet but both mufflers are in the 2 1/2 section behind the 3" cat .
It still has its AM radio tech computer and suffers no reversion crap/no pops spits OR drones anywhere .
I suggest that if you have to do something to reduce noise start at the back , its the cheapest easiest way that gives the least restriction in an exhaust system . Car manufacturers having been doing precisely this for some years now .
A .
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5307360
A .
thanks for the info, very helpful, so with the 3.5 system in there with stock dump and front pipe, its not helping it i assume haha, but i will invest in a 3 inch bellmouth for the dump/front.
i dont have an issue with sound at all, its quite quiet actualy...
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5307384
so ive heard
What im wondering will a 3 inch dump/front pipe into 2 3/4 catback be aiight..is there any real point buying a whole system for 1/4 of an inch?
Or will i be captain sloooow.........
the only place you may lose some power is high up in the revs. general driving around and even just reving up to around 5000rpm probably won't make a scrap of difference. anything above that i think you would have to put it on a dyno to see the difference in power. don't think you'd notice the power when driving it. if you were aiming for 250kw+ then it might be worth going 3" though.
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5307439
so if you were after more responsive midrange power the 3.5" exhaust is too large, is that what people are saying?
I was told by a tuner that a 2.5" custom made exhaust would be better than my 3.5" hks, this is what I was told when I told him I wanted to get a tune done for a HKS2835 with supporting mods...
I did say I was after good midrange response, and that I was not interested in ultimate peak power.
I didnt know wheather to trust him or not?
this is on a 33gtst
https://www.sau.com.au/forums/topic/325866-35-inch-to-big/#findComment-5308677
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
