Here we go;
Few weeks ago I was told that my CAS timing is very advanced. So I booked it in to get looked at by Boostworx here in Adelaide. Prior to this I removed my kick panel to find a Mines tuned ECU.
So yesterday I dropped the car off to BW asking them to check the CAS timing and also do a power run to check the Mines ECU isn't running too lean/rich and just to give me a basic power figure.
Going by my stanard boost gauge (ha!) it maxes out just past the first line between +0 and +7 giving me the conclusion its running about 10-11psi. Now the standard boost restrictor has been removed so 10-11psi should be achieved quiet easily.
Mod list is
  • Kakimoto Regu catback
  • Trust MX front pipe (I think its MX)
  • Apexi pods (very dirty)
  • bashed compliance cat - know very commodore spec
I went and picked the car up today to find out that all the timing and CAS is fine, AFRs are very good aswell as the O2 sensors. BUT I only made 160rwkw at 9psi and Shaun even said that I should be upwards of 190rwkw from 11psi. Now something is obviously wrong here and Shaun seems to think its the exhaust, which I am happy for it to be. But is there any other possibilities? I shouldn't need an EBC to run it higher than 9psi?
The car is daily driven so I'm not gonna completely going to go all out on a quest to make 11ty billion kw but I just want some advice and opinions on why I'm down on power.
https://www.sau.com.au/forums/topic/325889-160rwkw-from-r32-gtr/
Sounds about right to me to be honest for 9psi... (no idea why you are saying it's 11psi earlier in your post?)
+/- 15rwkw for dyno variance and so on and you are basically where it needs to be just based on that.
They are 206kw factory, so 160rwkw with 2psi extra and just exhaust is around the ballpark.
By all means drop the exhaust and so on (to check), but i highly doubt that has anything to do with it.
EDIT: re-read what you wrote and makes more sense.
Should I just leave it and add a EBC and new ECU to wake the sleeping giant?
I think if you up the boost to a more reasonable/steady 12psi, ECU/tune, bit of toying with cam gears and so on...
Would be around the 200-220rwkw marker and be a nice daily.
Also the compliance cat (even gutted) will be a problem as it'll be tapering down - i missed that earlier, only noticed it upon re-reading ya first post.
Either change it to a straight pipe or get a 3.5"-4" hi-flow cat onto it.
Hi-flow cat will be my next step. But what is confusing me is how every other results I've seen from 32,33,34 GTRs and they say standard boost and everything and they made 180-200ish. Just thought how could I be 30kw down from everyone else? I just was abit thrown back when I heard 160rwkw. I mean for a 2.6ltr TT that seems very low, RB20 with a few mods wouldn't be far off it.
Ye but they aren't running 9psi either.
Could be your motor is a tad tired, or the CAT as i've highlighted...
Without getting it all "working" it's going to be hard to workout exactly what in the setup is letting it down as currently you have a few things to sort out before going any further.
im not trying to rub it in but my rb20 made 155kw on 13 psi with just a catback and hks pod and iv got a mate with a completely stock gtr and were fair even, u would think youd get a fair increase from the front pipe alone, was it getting the right air fuel?
power sounds about right to me as well, raise the boost and you'll see good gains.
u cant really directly compare different models of gtr, they changed a bit over the years. :/
proper exhaust, boost up and tune should see 200+, if not more like 220 on a touch under 1 bar. had one make 225awkw with the same setup the other day
those air filters are unlikely to be helping either :cool:
It doesn't sound TOO bad but i would have guessed higher.
The quoted power figure of 206 is a bit iffy though. The 'gentleman's agreement' could be and was broken, and I would think there was a fair bit more based on seat-of-the-pants dyno runs.
However, remember, more than a few ponies have probably escaped the paddock in the last 17-21 years......
Mine put out 199kw on the BW dyno at 14.7psi on a 40 degree day, pretty much dead stock exhaust for nistune, cam gears (adjusted for response), catco hiflow cat, nismo front pipe and 3.5" catback
Doesnt sound that odd. Its pretty much a stocko GTR. So therefore its probably in the 13's and running traps of around 100mph. Which 160rwkw will do.
Add in varience of different dynos, and its not that low IMO.
My R34 (206kw again remember, although there are arguments a GTR is abit more from factory) made 160rwkw with a cat back and 12psi boost.
dude mine ran 161kw with exhaust. and have seen so many "exhausts" for gtrs that dont do shit unless you get a highflow cat.
put a high flow cat and cam gears with 14psi and it made 225kw on a pfc. tried old cat in it and dropped down to 180kw.....
do the cam gears and cat.... and get rid of the mines comp...
good luck
it seems low to me i made 246wk@tread
turbo back exhaust (twin 3" kakimoto N1 system)
K&N pods
15psi
and pfc
i would give the filters a very, very good clean or replace!
new fuel filter (Alot of people overlook this but i have found much better throttle response with new one)
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
