unsure if its the standard clutch or aftermarket clutch in my 33 (hasn't been changed since i bought it, previous owner wasn't sure either)
i've noticed lately that now i have to push the clutch all the way into the firewall otherwise it crunches, I used to only have to press the clutch 3/4 of the way to the firewall... my mate says its the clutch fork boot. would he be right?
If it helps, i noticed today sitting at the lights, on a slight incline.. clutch in, in first gear, take my foot off the brakes, (clutch still fully in) the car rolls back the slightest bit but as soon as i give a little gas the car stops moving backwards even tho the clutch is still fully depressed.. If i dont blip the gas the car keeps rolling backwards.
Any ideas?
Also, i dont have the cash just yet to fix it, is there much harm that can be done if i drive it for another week or so?
Edited by defari
https://www.sau.com.au/forums/topic/325899-r33-clutch-fork-boot/
it wont be the boot at all
either a pivot issue(often break), or clutch failure(pressure plate issue) of some sort, or bad adjustment caused by master of slave failure
maybe try bleeding the fluid for starters, first at the nipple on the master, then if still shit, bleed at the slave
  • 4 weeks later...
mates having a little bit of the same problems as yours, we will be replacing the slave as thats what we think is causing the problom, his is on holidays so will let you know when he gets back if its the problem or not.
Any ideas?
let me get this straight, while the clutch is fully pressed, and u press the accelerator, the car stops rolling back, even if you have had the clutch all the way in the whole time?
as lotsalag said, won't be a boot issue. the boot is simply a rubber seal. i'd say it will either be an adjustment issue or a pivot bolt issue. i've seen a few skylines snap the pivot bolt (mine included).
there is a small chance the that actual clutch fork is bent, but i doubt it unless you have a super heavy clutch.
Air in the system, worn master/slave cylinder, pivot ball snapped/worn, or pressure plate worn.
If you can get under the car, pull off the clutch release arm boot and have a look inside with a torch. Get a mate to sit in the car pushing the clutch pedal in and out. Will give you a good idea what is happening with it.
yep.. so its like the clutch is grabbing the slightest bit (hence the car stops rolling back) so even with the clutch fully in, its still grabbing the slightest bit..
i dont get any clutch smell, gears dont crunch. The clutch feels quite heavy (same as my old car with a hd clutch in it)
will bleed the master/slave over the weekend.
  • 9 months later...
What was the solution to this? i have the same problem :)
With the clutch pedal all the way in, i can either not get it into gear at all or if it does happen to (on occasion as it is temperamental), i roll forwards lol, while the pedal is still in.
Did this once and since had got the lines bled etc, has had new push rod and adjustment done and was all sweet for a while now its back to this again. ?? domokun.gif
Edited by Luke Vincent
nope all off rb25.. its all been changed over that i know of.
i got the 32 with an rb20 engine and 25box.. half way done
but as far as i know yes 33 master and slave.. what else is there to change?
    • Hey all, It's been a bit since I have been able to update.  I pulled the fuel pump, first off it was a "universal" pump and the strainer was very clogged, and it was folded over on itself.  I replaced the fuel pump and all is well....  No more stalling.
    • That's convinced me I'll bump up the G30-660 to 770   Any idea if the difference in boost pressure? Cheers
    • When: Saturday 24th of May 2025 - All day Where: Sydney Dragway, Eastern Creek Cost: Varies - Book direct with the GTR Festival Website We will be there on the day with a stand please reach out via our interest form if you wish to help out with the stand. Limited parking will be available in the display area, first in first served with current members getting priority, please register your interest with the link above also. Please post any great photos you take on the day on this thread and we will try use some in our e-mails/website/social media
    • Hey guys so turns out this project is going to be much bigger than I thought haha but I've done some my homework and have done a few panels on my car, but one part I can just not visualise is this. If I do a spot repair and I put filler in a dent for example and sand outside of the repair with 320 grit lets say so the primer can stick as I will only put primer on that repair and the surrounding area and then repaint the whole panel. Don't I need to make sure that I don't put primer on the old clear coat? I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down, it's still shiny. I thought putting paint on clearcoat or primer on clearcoat is a bad idea because it won't stick. So in this scenario it's a bit different to mine but imagine someone doing a spot repair and only painting that small section of repair but the new paint is landing on the old clearcoat. What am I missing?
    • I was immediately reminded that your location is QLD. Sounds like a perfect SEQ business idea.
