Was keen to see how other peoples vehicle weights compare as I think I am being stooged on my rego, I have had 3 32's now and I don't ever remember paying this much for rego for it
They think the Tare weight on my 32 GTST with no ABS is 1378kg, I took it down the wharf a little while ago and it said 1280 after a I removed 20KG of sound deadner and some extra insulation from the car. So rego for 6 months is $243.70
Edited by BANGN
https://www.sau.com.au/forums/topic/325901-compare-your-rego-papers/
The cost of registration in Western Austrlia is calculated on the weight of your vehicle. To put it simply, the more your car weighs, the more you're going to pay.
The most expensive i've seen rego go for is $17,000 for 12months for a mobile crane :cool:
The weight of your vehicle on our records can vary because when each vehicle is weighed it can differ due to but not limited to stereo equiptment, aftermarket parts (some wheels may be heavier etc etc), how much fuel is in your tank at the time and so on.
However in saying that, the difference in the cost of registration between a car that weighs 1300kg to a car that weighs 1500kg is not that much.
Of course there are other factors such as coupe/sedan/4wd/etc, 4/6/8/10/12cylinder, as that all affects the insurance premium and insurance class the govt charges for compulsory 3rd party.
That's the answer to your question, in a nutshell of course :/
I should no, I work for the department :P
So moral of the story is older cars are better in terms of paying less for rego like my dad's old Subaru which weight only ~900kg.
Sweet.
yeah each car is weighed indiviually before registration, but not on a yearly basis LOL.
Each car is weighed when brand new or for a new rego etc.
So the only real way to do it is de-register your car, strip it down to a bar chassis, weigh it, show us the weigh bridge certificate and pay rego on the weight of a bare chassis hahahaha
its dick all difference to pay for 12 months instead of 6 months, just reduces the pain on the pocket at the time.
I was just sure I only payed about 219 on my last 32, but thanks for clearing that syfon
they must of weighed mine with a few japs smuggling over in the boot
Edited by BANGN
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
