Was keen to see how other peoples vehicle weights compare as I think I am being stooged on my rego, I have had 3 32's now and I don't ever remember paying this much for rego for it
They think the Tare weight on my 32 GTST with no ABS is 1378kg, I took it down the wharf a little while ago and it said 1280 after a I removed 20KG of sound deadner and some extra insulation from the car. So rego for 6 months is $243.70
Edited by BANGN
https://www.sau.com.au/forums/topic/325901-compare-your-rego-papers/
The cost of registration in Western Austrlia is calculated on the weight of your vehicle. To put it simply, the more your car weighs, the more you're going to pay.
The most expensive i've seen rego go for is $17,000 for 12months for a mobile crane :cool:
The weight of your vehicle on our records can vary because when each vehicle is weighed it can differ due to but not limited to stereo equiptment, aftermarket parts (some wheels may be heavier etc etc), how much fuel is in your tank at the time and so on.
However in saying that, the difference in the cost of registration between a car that weighs 1300kg to a car that weighs 1500kg is not that much.
Of course there are other factors such as coupe/sedan/4wd/etc, 4/6/8/10/12cylinder, as that all affects the insurance premium and insurance class the govt charges for compulsory 3rd party.
That's the answer to your question, in a nutshell of course :/
I should no, I work for the department :P
So moral of the story is older cars are better in terms of paying less for rego like my dad's old Subaru which weight only ~900kg.
Sweet.
yeah each car is weighed indiviually before registration, but not on a yearly basis LOL.
Each car is weighed when brand new or for a new rego etc.
So the only real way to do it is de-register your car, strip it down to a bar chassis, weigh it, show us the weigh bridge certificate and pay rego on the weight of a bare chassis hahahaha
its dick all difference to pay for 12 months instead of 6 months, just reduces the pain on the pocket at the time.
I was just sure I only payed about 219 on my last 32, but thanks for clearing that syfon
they must of weighed mine with a few japs smuggling over in the boot
Edited by BANGN
    • Hi All, New member here, I've joined to help my son with an issue that is truly doing our heads in. I'll start with a bit of an overview. Chris carried out some modifications to the engine to try and extract just a little extra power out of the motor and make it a bit more efficient. Previous to this work, the car already had an upgraded exhaust, increased boost up to 14psi, modified standard turbo to metal impellers and slightly oversized, upgraded fuel pump, been dyno-tuned at JEM, and some other bits n bobs like coil packs etc. Before the current mods it was making 236rwkw at 14psi but after the new mods it now makes 209rwkw at 14psi. The work he carried out is as follows, timing belt service, water pump replacement, return to sump radium catch can, had oem head rebuilt and machined 0.2mm, fitted Athena cut ring head gasket 1.2mm thick, arp 2000 head studs, added rear prp head drain, added an external wastegate 40mm turbosmart welded off the stock manifold and plumbed back into a 3in dump. The car has been on the dyno and apparently the ignition is working, fuel flow and fuel pressure is fine, injectors are fine, spark plugs are working fine, Maf is working, O2 sensor is working, TPs sensor is working, VCT is working, CAS is working, boost leak test showed no boost leaks, compression test first crank cold 135psi and got to 150psi across all cylinders once cranking, timing is confirmed at tdc with a dial gauge and the cam dots line up, no blockages in intercoolerm throttle body or pre-turbo intake, no blockages in exhaust, cat conveter or down pipe, turbo looks fine and spins and wastegate looks fine and is new. Soz for all the detail but after all this, it has been in 3 times for dyno and each time comes back stating it's not going to make power. After the first (or second, can't remember now) trip to dyno we did find the timing out by one tooth and this improved things, but it is still well down. Does anyone have any ideas?  Any replies much appreciated as we're just not sure of which direction to take this. Regards Rob (Chris's Dad).
    • That's just a gauge, with a certain amount of electronic damping, and no-one cares if it is timely-accurate. I'd hesitate to use it for an ECU MAP input without knowing that it was a nice signal. Responsive but smooth. Not laggy. Not lumpy.
    • Took the dirty BMW to an actual drag meet so I could do a legit full pass on a sticky enough track and had a quiet goal to try and beat my PB in the old R33 GTS25t The time to beat:  R33 on stock RB25, Internal gate GT3076R on stock manifold tuned to about 17psi on BP98 and running on drag tyres: F20 M135i with intake, dump pipe and MHD OTS Stage 1 tune on street tyres - didn't even drop the tyre pressure: Kinda similar, and kinda way different
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
