I just picked up an R33 gtst s2. It needed a new diff and radiator so I've just finished replacing those and today I just noticed a slight whirring noise, which I think is coming from the timing belt cover.
Has anyone had this noise before? It only does it just off idle then it's fine after that. I've already ordered a new timing kit and water pump today which I'll fit on Friday, and hopefully that fixes it.
The motor has done just over 100,000kms so I'm gonna play it safe and replace the belts and pulley, and water pump while I'm at it.
https://www.sau.com.au/forums/topic/325911-is-my-timing-belt-on-the-way-out/
100k service = change timing belt. you're due so change it, interference motor means things get ugly if it snaps.
aftermarket belts eg gates make some noise anyway, but if yours hasn't been done and it's the OEM belt then it could be a warning sign that you should change it!!
i never heard a peep out of my OEM belt, got a gates on there now and it does make a slight whirr just off idle but they often do that.
Yea I'm prayin it's only the timing belt. I bought the car off a mate and he was straight up with the few things that were wrong with it and he did mention the timing belt hasn't been done yet. The motor sounds perfectly smooth, only the slight whirr just off idle. My parts should get here Thursday, so I should have it all completed by Friday arvy. I'm massively keen to get it on the road but don wanna playin Russian roulette n end up blowin the motor by drivin it with the old belt.
Hey guys, I am having the same issue ....HOWEVER,
my 96 R33 GTST (100km covered), was due for a timing belt, especially as I only just got the car a few months ago and didn't know if its been done.
I bought a timing kit, had it fitted, and within 2 weeks I am getting a whirr/growl from top of timing cover,
the noise only happens a few hundred RPM over idle and goes when revved higher, I have noticed that the growl goes once its warm (after a few mins) but have also notice when quite hot... I am getting a high pitched groan/moan from the same area.
Is the idler bearing shot? or tensioner? or is it just a noisy belt?
My other concern is that the tensioner has been set too tight and its worn the bearings ... is this possible?
Note, The noise wasn't there before the timing belt was done. :down:
Muchly appreciated if anyone else can shed some light?
Andy
New belts usually do that before theyre settled in, If it's a Gates timing belt, completely normal, might need retensioning down the track if it still does it
So a little growl just above idle for a few minutes is normal?
will it quieten down with age? Is this the same for the hum/whine when it is warm?
Thanks
so, i changed the timing belt yesterday and changed the tensioner and idler pulley while i was at it. The water pump was weeping out of the 'tell tale' hole so i replaced it as well.
It would have been approximately a 4 hour job, but my mate that was helping me accidently snapped off one of the 6mm bolts that holds the top timing cover on. Then it turned into a big mission to find a small enough ezi-out kit in town. And in the end I ended up drilling out the bolt and tapping it to an 8x1.25 hole instead and now its all sweet.
Anyways, now the new belt is fitted, the whirring noise that was there before, is now completely gone :-)
There is now the higher pitched whining/whirring noise... which is obviously characteristic of a new timing belt until it runs in.
But other than that, everything looks fine.
  • 4 weeks later...
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
