Hi all,
I just recently purchased an R32 GTR. Just fitted a boost gauge and noticed that it boosts up to around 20PSI. I'm not sure if there are stock turbo's in this car ... i know at 20PSI, it is no good for stock turbo's.. question is, how do i reduce the boost back to safer levels? say 12PSI?
Thanks!
https://www.sau.com.au/forums/topic/325931-r32-gtr-boosting-too-high/
at 20PSI this also no good for a stock engine (it will probably destroy it before long). i would start by finding the vacuum lines that come off the actuator on the turbos, make sure they are connected properly and follow them back looking for a split or a leak. or if someones fitted a boost tap you might find that somewhere along the lines. to reduce the boost pressure you first must find what has increased it.
if you cant work it out take it to a workshop (ideally one thats familiar with gtrs) they should be able to work it out pretty quickly.
right now you should assume it's stock standard as you dont know any different, so stay off the boost altogether until either a)its fixed. or b)you discover you have a built engine, aftermarket turbos and a tuned ecu.. lol
i'd like to think no one is wreckless enough to buy a gtr without asking the question "is it modified?" and get every detail if it is. neglecting this very simple step will result in you opening up a good ol' can of worms. i sort of made this mistake when i was 17 and it cost me dearly but we wont go into that.
only way really is to take off all the surrounding pipework to uncover them, if they are aftermarket they might have a brand name on the compressor cover, again probably a job for a tuning shop that knows their turbos and could positively identify them as there are some very minute external differences (if any) between a lot of turbos. if they are stock turbos that have been high flowed then it'll be even harder to tell. first thing i'd do is look at the compressor wheel, if its steel then its probably aftermarket. ceramic and it'll definately be stock, the ceramic ones dont like putting up with continued abuse.
No they dont! My R32 dropped the rear ceramic wheel a few months ago and the bits went back past the exhaust valves and destroyed my engine. You should see the scratches in the bores. Also if its still running the standard comp it will be having issues at that boost. its not the gauge is it. Can you borrow another one to double check?
I'd get it to a gtr experienced workshop asap. something is very wrong.
if they're stock turbos im surprised they're in one piece, if not stock and it has no other mods be very worried too!
fingers crossed its just a busted actuator hose, even so i'd be surprised if ur turbos or engine for that matter aren't damaged. :thumbsup:
sort of on the topic rb26 twin turbo setup the wastegate lever's attached to actuator rod with little CIRCLIP
any1 know a decent trick to getting them out without fkn around ... very tight spot
grow some ninja fingers. also use a small ultra fine flat blade screwdriver to flick it out maybe? and for the love of god dont drop the circlip.. it will vanish into thin air
^^^ +1 !!!!!!!!!!!!
yeah you can move it to the point where you can squeeze a screwdriver in there and prise it out, but sweet merciful fk don't drop it. i did and it landed on the plastic guard under the engine bay, the gf was not amused when i asked her to get it with her thinner arms, not amused at all haha
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
