Hi SAU Gents,
After nearly 12 months of hunting down a Genuine Series 3 R33 GTR front bar, I finally found one!
My 97' GTR is KR4 colour (dark silver), the bumper I have obtained is white, paint is in pretty good nik, but I want to strip the paint and start a new. Now I know not to use paint stripper as this can distort the shape of the plastic, and I really couldn't be bothered rubbing it right back. However, my question is this; Could I get this professionally sand blasted without damaging the pastic underneath.
Also would you guys suggest applying the paint in this procedure in an above 25 deg low humidity enviroment;
1./ A good etch primer
2./ Lightly rub back with 500 grit
3./ Apply high fill primer
4./ Lightly rub back with 280 grit finishing with 1200 grit
5./ Leave primer to fully dry out 24 - 48 hours
6./ Apply base coat (colour)
7./ Dry out 4 hours
8./ Apply top coat clear
Of course with all paint applications I will add a plastic additive given the fact this is plastic and will flex from time to time.
Also, whats good quality paint, Standox? I am pretty sure the paint is 2pak not acrylic? Correct me if i am wrong...
I have painted a few cars in my time, but never really done plastic bumpers.
Eperienced advice will be greatly appreciated!
Regards, Jason
Hi SAU Gents,
7./ Dry out 4 hours
Regards, Jason
BUMP Anybody?
Hi SAU Gents,
7./ Dry out 4 hours
Regards, Jason
First off, if you can't be bothered rubbing it back then I wouldn't bother painting it at all, get someone to do it professionally. Spray painting isn't something you should rush :D
Ok, considering it has already been painted, you don't need primer. If it has any scratches or dents that you want to fix then get some filler, filler acts as primer so you don't need to prime it again. If you are filling it, sand the bumper back with 240 grit, then spray on the filler. Once that has dried, sand most of it back with the 240 until you start to wear through to the paint underneath. Then go over it with 400 grit until it is all completely smooth. Make sure it is perfect, the paint won't hide anything.
Now you apply the base coat. Do not wait for it to dry before you apply the clear coat. You should apply the clear coat within 15 minutes, otherwise they will not chemically bond and the clear coat will peel off.
If you hit it perfectly straight out of the gun, then there shouldn't be any need to sand it back. Just buff it with some cutting compound to bring it up really smooth, and you're done :) Don't wax or polish the paint for 30 days, the paint really needs to set before you do.
*EDIT* Also, if you are painting in this cold weather, you need to warm the bumper up. You shouldn't paint anything that is under 22 degrees, otherwise the paint will not shine and will come out matte. Just get a heat lamp or stick the bumper over a heater until you can feel that it is quite warm to the touch. Don't forget to wipe it down before you spray it, get rid of any dust and grease from your skin if you touched it.
Edited by Hanaldo
First off, if you can't be bothered rubbing it back then I wouldn't bother painting it at all, get someone to do it professionally. Spray painting isn't something you should rush :happy:
If you hit it perfectly straight out of the gun, then there shouldn't be any need to sand it back. Just buff it with some cutting compound to bring it up really smooth, and you're done :blush: Don't wax or polish the paint for 30 days, the paint really needs to set before you do.
Hi Mate,
Autually I can be bothered rubbing it back, after all took me 12 months to find it.
Will definately take your advice on board mate, just got to work out how I can make an almost dust free environment in my garage. Might make up a plastic sheet room in my garage and seal it off!
Thanks a heap mate!
Hi Mate,
Thanks a heap mate!
why the hell do you want to rub all the white paint off? and what are you planning on painting it with? . if the white paint isn't cracked or scratched through to the plastic , don't waste your time :/ , if your worried about the silver chipping off and white coming through , that only happens if you don't face it back properly :D (i.e make sure you get in all the little corners etc , even if only with scotchbrite) , facing off to paint , i always use 600 to start and go over it with 800 (painting 2k) kr4 is a prick of a colour if your not expirienced with painting (have you ever seen a silver car that looks kinda splotchy= bad painter=looks shit) .
why the hell do you want to rub all the white paint off? and what are you planning on painting it with? . if the white paint isn't cracked or scratched through to the plastic , don't waste your time ;) , if your worried about the silver chipping off and white coming through , that only happens if you don't face it back properly :P (i.e make sure you get in all the little corners etc , even if only with scotchbrite) , facing off to paint , i always use 600 to start and go over it with 800 (painting 2k) kr4 is a prick of a colour if your not expirienced with painting (have you ever seen a silver car that looks kinda splotchy= bad painter=looks shit) .
Will be a challenge painting the KR4 thats for sure, but willing to give it ago! Have painted my old VS dunnydore years ago and it was a silver metallic, I paint matched it pretty well from memory and could not tell the difference. So will see how I go, might even put up some before and after shots, so you guys see how I go. Thanks for your advice also mate!
-0.6 deg this morning..
that's not cold.. its bloody freezing!
literally! ;)
Lol yeh, I recommend not painting on days as cold as this. Really ruins your coat.
Hi Mate,
Thanks a heap mate!
A good way of stopping a lot of dust is to make your whole garage damp. You don't need to soak the place, just lightly damp so that all the dust is weighed down and won't go flying around. Careful with this method though because moisture really isn't good for paint either... Also use your spray gun to spray some air around to blow off the majority of the dust from the bumper, and then use a clean cloth and lightly spray it with paint (not much, just so the cloth is sticky), and rub the bumper down with that. Should get rid of most of the dust.
Post some pictures up when you're done mate, keen to see how you go :P
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
