Hi,
Just installed new rb25 engine (after rebuild) with rb26 bottom end, wiseco forgies and HKS 256/8.8 in/ex camshafts.
The car idles with vacuum gauge reading ~ -0.43...-0.45 kpa which seems a bit low (usually ~0.6). I know that aftermarket cams can bring the vacuum down -- is this figures ok?
The second problem was that after initial ignition and fuel pressure tuning the car idles quite lean 17-18 AFR. Vacuum leakes where not found... Can cams cause this?
Have the cams been dialled in, that vacuum isnt too bad, as it sounds like it hasnt been tuned yet. When you say ignition and fuel pressure tuning, what do you mean exactly? Stock ecu?
the cams was installed with stock camgears -- so they have not been dialed in with a special procedures. as i read in this forums tomei poncams give the best result in default position. hks have very similar to tomei figures so i assumed it`s true for hks too.
ignition tuning is rotating the CAS with a ignition light to get 15 degrees on the crank pulley at idle.
fuel pressure tuning was setting the base fuel pressure at sard fpr (it was brand new and was set to 4 bar instead of 3bar -- but with 4 bar the idle was better).
ecu is power fc.
Tomei grind their cams at a lobe centre angle that is optimum for their bigger duration to give the right amount of overlap, this allows you to use stock cam pulleys. The HKS cams are ground to standard lobe centre angles, with increased duration the HKS items will be causing too much overlap hence the worse vacuum and the need to dial them in with adjustable cam pulleys.
ok, i understand how to dial in exhaust cam as it is possible to install adjustable cam gear on it, but what to do with intake camshaft -- it has nvcs gear so it can not be adjusted...
intake is adjustable fron the factory . take it out and look at the back of the cam gear or get one of these
http://www.trademe.co.nz/Trade-Me-Motors/C...n-293718049.htm
i read somewhere years ago it can be difficult to set mixtures at idle with big cams.
however, ur cams arent too aggressive, it may need further checking with the afr's u mentioned.
if its a stock computer ur kidding urself expecting it to run like this :thumbsup:
rb26 bottom end? changed stroke/cc etc? this will also not help the poor old stock ecu if thats whats still running(trying to run) it.
it`s not stock, it`s power fc as i mentioned before, so it`s not a big problem.
this is not true, please see the follwoing links for comparison:
Tomei Factory Camshaft Specs
HKS Camshaft Specs
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
