Depends how accurate you want it to be. If you just want it as a pretty moving gauge that attracts some attention then go the cheapest. If you actually want it for monitoring your boost then you will need to spend a bit more.
https://www.sau.com.au/forums/topic/325958-boost-gauges/#findComment-5307633
it doesnt have to be an expensive gauge to be accurate, just as long as it's a decent brand.
i'm using a vdo mech gauge right now. have been using it for a while. it's always spot on.
had a splitfire in the car when i bought it. seemed pretty good. autometer was also good.
i hooked up a calibre gauge. it was out by a couple of psi. autogauge, same crap.
https://www.sau.com.au/forums/topic/325958-boost-gauges/#findComment-5307713
if they are inaccurate it wont be by much, if your only running stock psi or there abouts, just get a cheapo one, if your pushing pounds then you need a good one, as its important to know exactly whats going on with the boost at higher levels.
https://www.sau.com.au/forums/topic/325958-boost-gauges/#findComment-5307716
Yeh it's not so much that they are out by much, although my old cheap vacuum gauge was out by 6 in/HG, it's more that they are prone to random inaccuracies which leaves you wondering if something is wrong or if it is just your gauge. If you are going to buy cheap then I would recommend getting a mechanical gauge, they tend to break easier but are more accurate than an equivalently priced electrical gauge, the cheap stepper motors just don't cut it. If you want electrical then I would spend a little bit more and get a decent gauge.
https://www.sau.com.au/forums/topic/325958-boost-gauges/#findComment-5307814
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
