this is new 2010 GSXR1000 has $4k in extras
has m4 exhaust K&N filter and power commander cold pazzo levers and end bars chrome GSXR heal hads tinted screen tail tidy and gel seat
done 4100ks not 1 mark on the bike sounds nice super fast pretty much new bike
have books and 1st service has been done just jump on and enjoy
here is a quick walk around vid the gel seat and tinted visor not on yet
https://www.sau.com.au/forums/topic/325992-2010-gsxr1000/
hey mate i got a 1995 nissan skyline r33
black
113kms
sunroof, 400r bar, 19"starcorp wheels(235 front-265 rear kumho all round)
excedy heavy button clutch just installed.
greddy front mount 600x300x100 custom stainless pipes. spitfire coilpacks, just replaced turbo no shaft play, apexi pod, 3" turbo back 5ziger exhaust, 8000k hid kit, no dints very straight body, paint is in resonable condition for original paint, nismo shifter, blue dash lights, boost gauge, sports steering wheel, coilovers, service it every 3000km with motul oil and ngk irridium plugs,
i use it to get ot work mon-fri and work is only 7km away from home, very easy life driven regularly so all works fine.
im sure theres stuff i missed but if ud like photos send me a text on 0433696875 so i can forward u some photos.
cheers bob.
swap for 33GTST or even a 34 or supra
https://www.sau.com.au/forums/topic/325992-2010-gsxr1000/#findComment-5397048
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
